Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Converting .ecore to .genmodel (EMF/GMF)
Converting .ecore to .genmodel (EMF/GMF) [message #70990] Thu, 08 February 2007 12:15 Go to next message
Originally posted by: elisabeth.olsen.bbvisuals.no
I'm using Eclipse 3.3.0, EMF 2.3.0 and GMF 1.1.0.
By using EMF i would like to generate a GMF project. I have some problems
getting things started, which I did not encounter in the previous releases.
I have created an .ecore model, and want to generate an .genmodel based on
that. When I try to generate the new model using EMF, I get the error shown
below.
Does anybody have an idea of what the problem might be?
Thank you!
Elisabeth
org.eclipse.emf.importer.ModelImporter.adjustEPackage(ModelI mporter.java:584)
org.eclipse.emf.importer.ModelImporter.adjustEPackages(Model Importer.java:573)
org.eclipse.emf.importer.ui.contribution.base.ModelImporterD etailPage.refreshModel(ModelImporterDetailPage.java:407)
org.eclipse.emf.importer.ui.contribution.base.ModelImporterD etailPage$3.execute(ModelImporterDetailPage.java:351)
org.eclipse.ui.actions.WorkspaceModifyOperation$1.run(Worksp aceModifyOperation.java:101)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1743)
org.eclipse.ui.actions.WorkspaceModifyOperation.run(Workspac eModifyOperation.java:113)
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:369)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:313)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 890)
org.eclipse.emf.importer.ui.contribution.base.ModelImporterD etailPage.refreshModel(ModelImporterDetailPage.java:374)
org.eclipse.emf.importer.ui.contribution.base.ModelImporterD etailPage.browseWorkspace(ModelImporterDetailPage.java:331)
org.eclipse.emf.converter.ui.contribution.base.ModelConverte rURIPage.doHandleEvent(ModelConverterURIPage.java:183)
org.eclipse.emf.importer.ui.contribution.base.ModelImporterD etailPage.doHandleEvent(ModelImporterDetailPage.java:182)
org.eclipse.emf.converter.ui.contribution.base.ModelConverte rPage.handleEvent(ModelConverterPage.java:145)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:928)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3465)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3079)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:820 )
at org.eclipse.jface.window.Window.open(Window.java:796)
at org.eclipse.ui.actions.NewWizardAction.run(NewWizardAction.j ava:182)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:499 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:545)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:490)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:402)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1945)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1909)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:425)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
org.eclipse.equinox.internal.app.EclipseAppContainer.callMet hod(EclipseAppContainer.java:522)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:147)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:104)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:74)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:354)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:170)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:339 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:283)
at org.eclipse.core.launcher.Main.run(Main.java:984)
at org.eclipse.core.launcher.Main.main(Main.java:959)
Re: Converting .ecore to .genmodel (EMF/GMF) [message #71033 is a reply to message #70990] Thu, 08 February 2007 12:23 Go to previous message
Elisabeth,
With a recent EMF 2.3 build (one after M4) we've provided validation
support for Ecore model constraints. So I would suggest right clicking
on the root EPackage of your .ecore and invoking validate. Likely you
have an EPackage without an nsURI. With this weeks build,
https://bugs.eclipse.org/bugs/show_bug.cgi?id=172654 will ensure that
this validation is invoked as you import the .ecore in the wizard. If
this scenario involves reconciling an old .genmodel, try to open the old
..genmodel in the Generator, which will also tell you about any problems
in your Ecore model.
Elisabeth wrote:
> below.
> Thank you!
> Elisabeth
> java.lang.NullPointerException
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: Converting .ecore to .genmodel (EMF/GMF) [message #602364 is a reply to message #70990] Thu, 08 February 2007 12:23 Go to previous message
Elisabeth,
Elisabeth wrote:
> below.
> Thank you!
> Elisabeth
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Ed Merks
Previous Topic:Converting .ecore to .genmodel (EMF/GMF)
Next Topic:Teneo: Identity (ID) scope conflicts
Current Time: Tue Apr 16 21:41:50 GMT 2024
Powered by FUDForum. Page generated in 0.39644 seconds
