Re: Source file path not valid when debugging [message #686182 is a reply to message #685544] |
Tue, 21 June 2011 05:14 |
On Fri, 17 Jun 2011 14:03:24 -0400, Billy Blanks wrote:
> Hello,
> I am still trying to learn Eclipse so please bear with me. I have always
> had no problems when debugging but today. While debugging, Eclipse
> failed to find one of the JSPs I was trying to debug. I received the
> following error:
> Resource '/path' does not exist.
> I have tried the Edit Source Lookup Path and the Lookup Source options
> with no avail. Please help me to figure out what is going on.
> -Billy
Not sure, try deleting the runtime debug configuration and re-run
or try creating a new project for testing this, similar to your
existing one and does it work? If not then I'd say try running
eclipse with the -clean option and if your stuff is checked
into source control then move the workspace to an archive location
and check the project(s) out new and try again.
FUDForum. Page generated in 0.08235 seconds
