Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Teneo: performance fall of HibernatePersistableEList
Teneo: performance fall of HibernatePersistableEList [message #68304] Fri, 19 January 2007 12:27 Go to next message
Ilya Klyuchnikov is currently offline Ilya KlyuchnikovFriend
Member
When list is already loaded by eager loading or by subselect fetch
loading then HibernatePersistableEList isLoaded() method in this case
calls doLoad. doLoad() method begins transaction and commit transaction
when there is no need for it.
I have profiled my eclipse application:
HibernatePersistableEList.doLoad was called 455 times and cumulative
time was 91 secs.
JDBCTransaction was called 456 and cumulative time was 76 secs.
The first transaction is initial loading and the next transactions are
not needed at all.
So my application looses many idle time.
Is it possible not to begin and commit transaction in
HibernatePersistableEList when list is already loaded?
Thanks.
Ilya.
Re: Teneo: performance fall of HibernatePersistableEList [message #68316 is a reply to message #68304] Fri, 19 January 2007 12:38 Go to previous messageGo to next message
Martin Taal is currently offline Martin TaalFriend
Hi Ilya,
Are you using the latest teneo build? Something similar should have been solved in the latest build.
See also the newsgroup discussion here:
http://dev.eclipse.org/newslists/news.eclipse.technology.emf t/msg01687.html
gr. Martin
> time was 91 secs.
> not needed at all.
> Thanks.
> Ilya.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Teneo: performance fall of HibernatePersistableEList [message #68325 is a reply to message #68316] Fri, 19 January 2007 12:51 Go to previous messageGo to next message
Member
I am using Teneo I200701051518.
Described problem is real problem for me.
Details:
I have about 500 collections already loaded by fetch subselect - 2-3
collections are loaded from HibernatePersistableEList's point of view
and delegates for others are loaded.
So when I touch collections with already loaded delegates -
HibernatePersistableEList.isLoaded() is called. This method reveals that
delegate is loaded but isLoaded field is false. So it calls doLoad()
method. DoLoad() method begins and commit transaction (but there is no
need for it - cause delegate is already loaded). transaction.commit
takes very long time.
BTW I have made workaround in my app - I have introduced
SessionController (so HibernatePersistableEList doesn't begin and commit
transactions) for my resource and time of touching of all my collections
(from UI) reduced from 91 sec to 9 sec.
So main point: there is no need to begin and commit transaction in
HibernatePersistableEList when delegate is already loaded.
Ilya
Martin Taal wrote:
> Hi Ilya,
> solved in the latest build. See also the newsgroup discussion here:
> gr. Martin
>> transaction when there is no need for it.
>> time was 91 secs.
>> not needed at all.
>> Thanks.
>> Ilya.
Re: Teneo: performance fall of HibernatePersistableEList [message #68336 is a reply to message #68325] Fri, 19 January 2007 12:52 Go to previous messageGo to next message
Yes I agree, this can be improved. Can you enter a bugzilla for this? I plan to do a new release
next week which will contain a fix for this.
gr. Martin
> Details:
> Ilya
> Martin Taal wrote:
>> Hi Ilya,
>> been solved in the latest build. See also the newsgroup discussion here:
>> gr. Martin
>>> time was 91 secs.
>>> are not needed at all.
>>> Thanks.
>>> Ilya.
The Netherlands
Re: Teneo: performance fall of HibernatePersistableEList [message #68347 is a reply to message #68336] Fri, 19 January 2007 13:03 Go to previous message
Member
I have created bug report #171035.
Ilya
> plan to do a new release next week which will contain a fix for this.
> gr. Martin
>> Details:
>> that delegate is loaded but isLoaded field is false. So it calls
>> doLoad() method. DoLoad() method begins and commit transaction (but
>> there is no need for it - cause delegate is already loaded).
>> transaction.commit takes very long time.
>> commit transactions) for my resource and time of touching of all my
>> collections (from UI) reduced from 91 sec to 9 sec.
>> Ilya
>> Martin Taal wrote:
>>> Hi Ilya,
>>> gr. Martin
>>>> case calls doLoad. doLoad() method begins transaction and commit
>>>> time was 91 secs.
>>>> Thanks.
>>>> Ilya.
Re: Teneo: performance fall of HibernatePersistableEList [message #601364 is a reply to message #68304] Fri, 19 January 2007 12:38 Go to previous message
Hi Ilya,
gr. Martin
> time was 91 secs.
> not needed at all.
> Thanks.
> Ilya.
The Netherlands
Re: Teneo: performance fall of HibernatePersistableEList [message #601375 is a reply to message #68316] Fri, 19 January 2007 12:51 Go to previous message
Member
Details:
Ilya
Martin Taal wrote:
> Hi Ilya,
> gr. Martin
>> time was 91 secs.
>> not needed at all.
>> Thanks.
>> Ilya.
Re: Teneo: performance fall of HibernatePersistableEList [message #601377 is a reply to message #68325] Fri, 19 January 2007 12:52 Go to previous message
gr. Martin
> Details:
> Ilya
> Martin Taal wrote:
>> Hi Ilya,
>> gr. Martin
>>> time was 91 secs.
>>> Thanks.
>>> Ilya.
The Netherlands
Re: Teneo: performance fall of HibernatePersistableEList [message #601383 is a reply to message #68336] Fri, 19 January 2007 13:03 Go to previous message
Member
Ilya
> gr. Martin
>> Details:
>> Ilya
>> Martin Taal wrote:
>>> Hi Ilya,
>>> gr. Martin
>>>> time was 91 secs.
>>>> Thanks.
>>>> Ilya.
Previous Topic:Teneo: performance fall of HibernatePersistableEList
Next Topic:OCL link constraint queries
Current Time: Fri Feb 26 11:01:56 GMT 2021
Powered by FUDForum. Page generated in 0.03003 seconds
