Home » Newcomers » Newcomers » Trying to setup up work space in eclipse(Need help setting up a web developer work space.)
Trying to setup up work space in eclipse [message #682640] |
Sat, 11 June 2011 18:14 |
Kristoffer la Cour Messages: 1 Registered: June 2011 |
Junior Member |
Okay, so i'm trying to get started with eclipse, I've set up a project that i'm currently working on, and are now trying to setup the work space in a fitting way.
My project involves PHP, HTML, CSS, JavaScript, jQuery and MySQL.
I've been going through the settings to get the right syntax coloring and such, but now i want to add jQuery to my project...
I've been googleing for how to do it, but the links i find are broken or i'm unable to download the plugins...
If anyone know what i should do to add jQuery, please let me know...
Also, i would like the default encoding to be set to UTF-8, so when i create a new document, the encoding is UTF-8, and if possible, alert me if a document isn't UTF-8 encoded.
That should be all for now, and thanks.
Edit: one more thing, eclipse doesn't seem to accept a few functions like the string.match() function, do i need to activate/add a list of these somewhere?..
[Updated on: Sat, 11 June 2011 18:23] Report message to a moderator
Re: Trying to setup up work space in eclipse [message #682694 is a reply to message #682640] |
Sat, 11 June 2011 21:27 |
You might find more kindred spirits and better answers to this question
in the Eclipse PDT forum.
Re: Trying to setup up work space in eclipse [message #684466 is a reply to message #682694] |
Wed, 15 June 2011 15:35 |
Eric Rizzo Messages: 3070 Registered: July 2009 |
Or the ATF forum or the Web Tools (WTP) forum. Those are more geared
towards the JavaScript tooling in Eclipse.
Eric
Current Time: Thu Apr 25 15:16:27 GMT 2024
Powered by FUDForum. Page generated in 0.09332 seconds
