Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » How to call invoke transform agasin each eClass
How to call invoke transform agasin each eClass [message #68090] Sat, 13 January 2007 08:01 Go to next message
Originally posted by: 2236249.gdvnet.com
Hi, I am using emft to gen some codes from a ecore model.
My ecore model has a EPackage and more than one eClass, I want my templates
to transform each eClass.
That is, I have a templte list.emf
I have an ecore model which contains classes: Ant, Cat, Rat
I want to get results
list_ant.jsp
list_cat.jsp
list_rat.jsp
Also since the class name can change anytime, and more classes can be added
in.
Thanks in advance!
Re: How to call invoke transform agasin each eClass [message #68207 is a reply to message #68090] Tue, 16 January 2007 12:40 Go to previous messageGo to next message
Lipan,
Have you looked at the JET2 examples or looked at the JET articles on
the EMF documentation page?
> list_ant.jsp
> list_cat.jsp
> list_rat.jsp
> in.
> Thanks in advance!
Re: How to call invoke transform agasin each eClass [message #68272 is a reply to message #68090] Tue, 16 January 2007 16:55 Go to previous messageGo to next message
Paul Elder is currently offline Paul ElderFriend
Some useful links:
The EMFT JET (aka JET2) Getting started help pages:
http://help.eclipse.org/help32/index.jsp?topic=/org.eclipse. jet.doc/gettingStarted/index.xhtml
An introductory article on JET2:
http://www-128.ibm.com/developerworks/opensource/library/os- ecl-jet/
Paul
"lipan" <2236249@gdvnet.com> wrote in message
news:eoa3j1$bn8$1@utils.eclipse.org...
> templates to transform each eClass.
> list_ant.jsp
> list_cat.jsp
> list_rat.jsp
> added in.
> Thanks in advance!
Re: How to call invoke transform agasin each eClass [message #69204 is a reply to message #68272] Sat, 27 January 2007 15:43 Go to previous messageGo to next message
Thanks for your response
I have read this pages, and have done some emft templates.
But I don't think they can answer my question.
Maybe it is my mistake. But follwing the document, I cann't get what I want
I have a package, it has classes Ant, Cat, Rat
Then I have a tempalte list.emf
What I want is three files,
list_ant.jsp which is based on Ant's properties
and
list_cat.jsp which is based on Cat's properties
This is my list.emf:
<html>
<body>
<c:iterate select="/contents/eClassifiers" var="currNode">
Name = <c:get select="$currNode/@name" />
</c:iterate>
</body>
</html>
yes it produce a file, which list all these classifiers, but I only want
three files, each list one classifiler
I thought <ws:file/> can help me, but it can only process the whole ecore
module(which list all 3 classifers)
I think it may be useful to write something like
<ws:file template="list.emf" processnode="$currNode/@name" />
</c:iterate>
but ws:file can't work this way.
> Some useful links:
> Paul
>> list_ant.jsp
>> list_cat.jsp
>> list_rat.jsp
>> added in.
>> Thanks in advance!
Re: How to call invoke transform agasin each eClass [message #69225 is a reply to message #69204] Mon, 29 January 2007 13:21 Go to previous messageGo to next message
Lipan:
Your second instinct is nearly right:
> </c:iterate>
But, JET doesn't do parameter passing the way you are expecting (or for that
matter, the way I'd like it to). The variable 'currNode' is global, so you'd
do the following:
In templates/main.jet:
<ws:file template="templates/list.emf.jet"
path="some-project/list_{$currNode/@name}.jsp"/>
</c:iterate>
Note the XPath expression in braces { } embedded in the path attribute. This
can be enhanced using functions to make the name lowercase:
path="some-project/list_{lower-case($currNode/@name)}.jsp"/ >
Finally, in templates/list.emf.jet, you would do whatever it is you want:
This is the content for: <c:get select="$currNode/@name"/>
Paul
Re: How to call invoke transform agasin each eClass [message #69321 is a reply to message #69225] Tue, 30 January 2007 06:01 Go to previous message
Thank you!
> Lipan:
>> </c:iterate>
> that matter, the way I'd like it to). The variable 'currNode' is global,
> so you'd do the following:
> </c:iterate>
> This can be enhanced using functions to make the name lowercase:
> Paul
Re: How to call invoke transform agasin each eClass [message #601296 is a reply to message #68090] Tue, 16 January 2007 12:40 Go to previous message
Lipan,
> list_ant.jsp
> list_cat.jsp
> list_rat.jsp
> in.
> Thanks in advance!
Ed Merks
Re: How to call invoke transform agasin each eClass [message #601332 is a reply to message #68090] Tue, 16 January 2007 16:55 Go to previous message
Some useful links:
Paul
> list_ant.jsp
> list_cat.jsp
> list_rat.jsp
> added in.
> Thanks in advance!
Re: How to call invoke transform agasin each eClass [message #601677 is a reply to message #68272] Sat, 27 January 2007 15:43 Go to previous message
and
<html>
<body>
</c:iterate>
</body>
</html>
</c:iterate>
> Some useful links:
> Paul
>> list_ant.jsp
>> list_cat.jsp
>> list_rat.jsp
>> added in.
>> Thanks in advance!
Re: How to call invoke transform agasin each eClass [message #601680 is a reply to message #69204] Mon, 29 January 2007 13:21 Go to previous message
Lipan:
> </c:iterate>
do the following:
</c:iterate>
Paul
Re: How to call invoke transform agasin each eClass [message #601717 is a reply to message #69225] Tue, 30 January 2007 06:01 Go to previous message
Thank you!
> Lipan:
>> </c:iterate>
> </c:iterate>
> Paul
Previous Topic:[OCL] String Operations
Next Topic:Query 1.1M4
Current Time: Thu Feb 25 21:55:01 GMT 2021
Powered by FUDForum. Page generated in 0.02580 seconds
