Re: Versions of OCL [message #68018 is a reply to message #67832] |
Thu, 11 January 2007 22:34 |
Hi, Gaff,
In the 1.1 release, OCL has moved to the Modeling Project. The newsgroup
for OCL has likewise moved to eclipse.modeling.mdt.uml2.ocl.
Downloads of OCL 1.1 are available at:
http://www.eclipse.org/modeling/mdt/downloads/?project=uml2- ocl
There you will find the 1.1M3 build as well as 1.1M4. I think it is a
mistake that 1.1M4 appears on the old EMFT downloads page.
Christian
Gaff wrote:
> I'm relatively new to Eclipse so am not too familiar with versions of
> releases, etc.
> I want to use a plugin that uses OCL, the version that is specified is EMF
> OCL build 1.1M3, form the download page:
http://www.eclipse.org/emft/downloads/index.php?project=ocl& amp;showAll=0&showMax=5
> all I can see is the M4 and M2 builds. Can I safely use a build that is
> higher than the one specified?
> If so, is this also true in general for builds etc in Eclipse?
> Thanks, Gaff
FUDForum. Page generated in 0.01994 seconds
