problem in applying patch to java project [message #677200] |
Tue, 07 June 2011 20:13 |
gaurav Messages: 1 Registered: June 2011 |
Junior Member |
hi all,
I am trying to apply a patch to a Java project in my eclipse workspace and I go to
"TEAM--APPLY PATCH" and on selecting the patch file and path it shows the matching correctly in the patch view but on clicking on FINISH it throws an error saying PATH MUST INCLUDE PROJECT AND RESOURCE NAME .
Kindly give your suggestions to solve it as I need to get it done with urgently.
I looked at the error log and here's the stack trace for the error.
java.lang.reflect.InvocationTargetException
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:421)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java:1008)
at org.eclipse.compare.internal.patch.PatchWizard.performFinish(PatchWizard.java:173)
at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDialog.java:811)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:430)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:624)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:234)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4066)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3657)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
at org.eclipse.jface.window.Window.open(Window.java:801)
at org.eclipse.team.internal.ui.synchronize.patch.ApplyPatchOperation.openWizard(ApplyPatchOperation.java:159)
at org.eclipse.team.internal.ui.synchronize.patch.ApplyPatchOperation.run(ApplyPatchOperation.java:217)
at org.eclipse.team.internal.ui.actions.ApplyPatchAction.execute(ApplyPatchAction.java:53)
at org.eclipse.team.internal.ui.actions.TeamAction.run(TeamAction.java:515)
at org.eclipse.team.internal.ui.actions.TeamAction.runWithEvent(TeamAction.java:549)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginAction.java:241)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2640)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:664)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:115)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:620)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:575)
at org.eclipse.equinox.launcher.Main.run(Main.java:1408)
Caused by: java.lang.IllegalArgumentException: Path must include project and resource name: /
at org.eclipse.core.runtime.Assert.isLegal(Assert.java:63)
at org.eclipse.core.internal.resources.Workspace.newResource(Workspace.java:1795)
at org.eclipse.core.internal.resources.Container.getFolder(Container.java:221)
at org.eclipse.compare.internal.patch.Patcher.createPath(Patcher.java:420)
at org.eclipse.compare.internal.patch.Patcher.applyAll(Patcher.java:246)
at org.eclipse.compare.internal.patch.WorkspacePatcher.applyAll(WorkspacePatcher.java:78)
at org.eclipse.compare.internal.patch.PatchWizard$1.execute(PatchWizard.java:163)
at org.eclipse.ui.actions.WorkspaceModifyOperation$1.run(WorkspaceModifyOperation.java:106)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:1975)
at org.eclipse.ui.actions.WorkspaceModifyOperation.run(WorkspaceModifyOperation.java:118)
at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:121)
eclipse.buildId=M20110210-1200
Gaurav
FUDForum. Page generated in 0.07398 seconds
