Help with Eclipse Helios SR2 for Win x64 [message #676393] |
Sat, 04 June 2011 05:22 |
Missing name Missing name Messages: 2 Registered: June 2011 |
Junior Member |
Hi, for starters, this is my first post. Second, I am having some trouble using Eclipse, when I create a new Java class and run it, I constantly get a ClassNotFoundException, these Java classes run just fine in other IDEs (i.e. - BlueJ). I don't get this error when I run an older class. If I run a file created outside Eclipse, it gives the option for ant builds, and I don't get an error, but the file won't execute at all. Any help would be apreciated.
Re: Help with Eclipse Helios SR2 for Win x64 [message #676461 is a reply to message #676393] |
Sat, 04 June 2011 14:55 |
David Wegener Messages: 1445 Registered: July 2009 |
Make sure that the class file has been compiled.
Re: Help with Eclipse Helios SR2 for Win x64 [message #677228 is a reply to message #676487] |
Tue, 07 June 2011 21:16 |
On 6/4/2011 3:40 PM, forums-noreply@eclipse.org wrote:
> How do I do that?
From the Project menu in the menu bar, make sure that Build
Automatically is enabled. Unless you've found specific circumstances in
which you want to turn it off, you can save yourself a lot of headaches
by just leaving it on.
Nitin Dahyabhai
Eclipse WTP Source Editing and JSDT
IBM Rational
_
Nitin Dahyabhai
Eclipse Web Tools Platform
FUDForum. Page generated in 0.08169 seconds
