Re: importing proyect from netbeans [message #674852 is a reply to message #674843] |
Sat, 28 May 2011 23:07 |
On 2011.05.28 15:39, mario wrote:
> Good morning i´d like to know if you can help me.
> I´ve done a graphical interface in netbeans because of it is easier but
> now i´d like to import the proyect to eclipse. After fighting for a long
> time i got it without any error but when i play it in eclipse appear the
> next error.
> editor does not contain a main type
> if i´m not wrong, it means that i have to create a class with the method
> main but my question is... if the proyect runs well with netbeans why
> not with the eclipse.
> anyone knows how to fix it??. Any ideas would be good
> thanks for everything
> regards
> Mario
I once tried NetBeans and found it to be a very nice environment. I
don't remember NetBeans obviating the need to code a static main method.
In any case, unless you use a specific UI framework independent from
NetBeans, you'll run into trouble using Eclipse. Such projects aren't
compatible.
Re: importing proyect from netbeans [message #675265 is a reply to message #675247] |
Mon, 30 May 2011 23:14 |
On 2011.05.30 16:15, mario wrote:
> once i used netbeans to make a graphical interface and i could use the
> code in eclipse without any problem. well... just one.. the witdh but
> nothing serious. now i can see some error and i cant run it. but that
> interface work before...
> any idea???
It depends on what you're doing, what framework you're using. No one can
guess this as you've posted nothing specific about what doesn't work.
FUDForum. Page generated in 0.08452 seconds
