Execute eclipse in Windows, but compile and execute in another Linux machine [message #674766] |
Sat, 28 May 2011 11:05 |
Tom Messages: 4 Registered: May 2011 |
Junior Member |
There is a project built using makefiles. This project has to be compiled and executed in a linux machine for several reasons.
The problem with this machine is that I can only use the terminal, and there is no chances to install anything, so this is the only way I can access the machine.
What I can do is mount the this in windows.
My idea is to install eclipse on Windows and modify the code from there.
But I want to take full profit of eclipse, specially the debugger, and what I'm wondering is if it is possible to configure eclipse so that it stablish, let's say a ssh conection with the machine, and when I tell eclipse compile, it has issue a make command throw the ssh. The same for the dubbging/running. Eclipse runs the application on the external machine, and all the breakpoints I just created in eclipse are send throw the ssh link to the gdb.
This is my idea, maybe eclipse have something else.
What i cannot use a cross compiler and compile the code in windows. There are several dependencies I cannot fullfil and also my Windows machine is much more slower than the Linux one.
Any idea?
Tom
Re: Execute eclipse in Windows, but compile and execute in another Linux machine [message #674792 is a reply to message #674766] |
Sat, 28 May 2011 14:54 |
On 2011.05.28 5:05, Tom wrote:
> access the machine.
> Any idea?
> Tom
This is more relevant to Eclipse CDT. Ask in that forum.
FUDForum. Page generated in 0.08733 seconds
