Home » Newcomers » Newcomers » Bad Habbits(several small problems, bothering me the whole day)
Bad Habbits [message #673521] |
Mon, 23 May 2011 23:24 |
SaHiB Messages: 5 Registered: May 2011 |
Junior Member |
Hi everbody,
i hope, you can help me with some of my "problems".
I recently changed from an other editor to eclipse, but there are some of it's habbits which bother me.
I'm using the current Helios version for programming php/html/css/js
- is there any posibility to bind code-templates to a key?
- can I teach eclipse to insert a '<br />' when I'm hitting ctrl+return in html-mode, instead of a linebreak?
- when mixing html and php, I usually use short tags for outputs. When I start typing <? it auto inserts a <?php ?>, so if i want to use shorttags <?=$foo?> this habbit costs a lot of time - can I deactivate it?
- where is the definition list for php keywords stored? I like to have AND/OR also in the keywordlist for syntax highlighting, but don't know where to add it.
- really bothering is that the eclipse viewport jumps, when undoing something. If I hit strg+z, it the last step is undone, but the viewport also jumps, so the line where the undoing action happend "jumps" to line 26 of the visible lines. How can i stop this from happening?
- when I have an IF in php, followed by a single command, I dont use brackets, but intend the command with one tab in the next line. ctrl+i dont recognize this dependency between the command and the IF, so it dont intend the code, that is only executet if the condition is true (same problem with loops)
Example:
if(true)
foo();
//ctrl+i changes it to
if(true)
foo();
- another problem with ctrl+i and with shift-tab, is removing indenting. It works fine, as long a there are tabs used for intending. But as soon as you'll get a file, that uses 4 whitespace instead of one tab (or even mixes whitespace and tabs), it fails. How can I make eclipse, to treat 4 white spaces as one tab, when shifting code to the left?
- when double clicking on code to select a word, some of the selecting habbits of eclipse are not that productiv for me.
Example: foo.class.php - double click on foo should select only foo, but in eclipse the whole string foo.class.php is selected. Same problem with foo/bar. Is there any file where I can edit those "stop selecting" characters ?
- A last thing: I'd like to make some small text-manipulating-custom-scripts running over my Code, like removing whitespaces, changing some chars against others and stuff like that - is there an easy to use interface for userdefinded scripts, where I can access the content of the current editor and modify it, or do I need to programm a whole plugin for those simple tasks?
thats all so far, a lot of questions and I know, my english isn't the best, but I hope you'll understand it anyways. I also searched for all topics with google, but either I use the wrong keywords, or I am the only one, that is bothered by these things...
Anyway: thanks for yur help and your patience
greetings
SaHiB
[Updated on: Mon, 23 May 2011 23:25] Report message to a moderator
Re: Bad Habbits [message #675208 is a reply to message #675099] |
Mon, 30 May 2011 15:09 |
On 2011.05.30 3:57, SaHiB wrote:
> 413 Views, 9 small questions and not a single answer :(
> Is every of these 9 problems impossible to solve? Am I the only one,
> bothered by these usability problems?
> Even an "it's impossible" answer would be a help...
> please help
> thank you guys!
First, your English isn't a problem at all. In fact, it's very good.
Second, you've asked your question in the wrong forum. I would have
chosen the Eclipse PDT forum where you'll find PHP developers like yourself.
Hope this helps.
Re: Bad Habbits [message #675421 is a reply to message #675208] |
Tue, 31 May 2011 13:25 |
>> please help
>> thank you guys!
> yourself.
Third, you've asked too many questions. Break it down in to smaller
posts (but don't post them all at the same time) to make it easier to
respond.
Denis Roy
Eclipse Webmaster -- webmaster@eclipse.org
Re: Bad Habbits [message #675470 is a reply to message #675421] |
Tue, 31 May 2011 15:53 |
Junior Member |
Denis Roy wrote on Tue, 31 May 2011 09:25On 05/30/2011 11:09 AM, Russell
respond.
wouldnt that be spam, if if make 9 posts in a row?
beside, all the problems are non-php-specific, they are abound handling the editor and I think, these probles will ouccure also in other languages like java.
For example the undo-jump thing - isn't that a problem for you, denis? Am I the only one confused by these jumps?
[Updated on: Tue, 31 May 2011 15:53] Report message to a moderator
Current Time: Thu Apr 25 20:52:13 GMT 2024
Powered by FUDForum. Page generated in 0.08905 seconds
