Curved tabs for Eclipse [message #670949] |
Mon, 16 May 2011 10:46 |
Ivan Raichs Messages: 17 Registered: April 2011 |
Junior Member |
By now I'm working on a presentation Factory for Eclipse Helios, not an Eclipse RCP. As I've never done any, I'm taking as a model the R21 presentation Factory which perfectly documents all the classes and methods, making it easy to understand.
The R21 presentation Factory gives by default square tabs which I want to change to the curves ones. I've been googling and I've seen that using the org.eclipse.swt.custom.CTabFolder and org.eclipse.swt.custom.CTabItem libraries I can be easy done.
The problem is that when adding those libraries to the presentation Factory the class gives lots of errors.
Which is the best way to achieve curved tabs without using those libraries ?
Any help, suggestion or help will be highly appreciated.
Ivan RAICHS
FUDForum. Page generated in 0.08314 seconds
