Plugin Installtion [message #670826] |
Sun, 15 May 2011 19:10 |
Niko Messages: 1 Registered: May 2011 |
Junior Member |
I installed Eclipse Modeling Tools 64Bit Version (Helios) and want also install UML2 Tools.
I get following error:
Cannot complete the install because one or more required items could not be found.
Software being installed: UML2 Diagramming (Incubation) 0.9.0.v200906190654 (org.eclipse.uml2.diagram.feature.group 0.9.0.v200906190654)
Missing requirement: UML2 Diagramming (Incubation) 0.9.0.v200906190654 (org.eclipse.uml2.diagram.feature.group 0.9.0.v200906190654) requires 'org.eclipse.gmf.runtime.notation.providers 0.0.0' but it could not be found
If i want to install the GMF Plugin something else is missing.
Edit: My aim is to build a class diagram and generate code with EMF(core). I hope this is possible.
[Updated on: Sun, 15 May 2011 19:32] Report message to a moderator
Re: Plugin Installtion [message #670840 is a reply to message #670826] |
Sun, 15 May 2011 19:44 |
Ed Merks Messages: 33140 Registered: July 2009 |
Niko,
You're probably better off looking into how to installing Papyrus given
that it's more complete and better supported. If you have problems with
that, use the eclipse.papyrus forum.
> could not be found
> missing.
Ed Merks
FUDForum. Page generated in 0.09060 seconds
