Re: Eclipse fails to start if -Xmx option is specified a higher value. [message #667008 is a reply to message #666986] |
Mon, 25 April 2011 13:22 |
Mon, 25 Apr 2011 07:01:27 -0400, /the accused/:
> I'm running inside a VM. In the VMWare settings, I can see that the
> RAM alloted is 6016 MB which is 6GB. As recommended in our company I
> used -Xmx1024m (the default was 512) but eclipse fails to start,
> saying jvm exit code -1. The maximum value for Xmx that works is 660m.
> My Eclipse build details are:
> Eclipse Platform 3.5.2.M20100211-1343 org.eclipse.platform.ide
> Java EE IDE Feature 1.2.2.20100217-2310
> org.eclipse.epp.package.jee.feature.feature.group
> Why is this happening? Please help before I shoot myself.
Please, stop threaten you would commit suicide (it's neither funny
nor helpful). Try running a simple HelloWorld using -Xmx1024M and
see if the problem persists. If the JVM fails to load again, then
it is not Eclipse specific but specific to the environment you're
trying to start the JRE in. Check there's enough free physical RAM
to start the JRE using the given heap options.
Stanimir
FUDForum. Page generated in 0.07586 seconds
