Zipping up files to "build" a project [message #666594] |
Thu, 21 April 2011 08:53 |
Nick Bloor Messages: 1 Registered: April 2011 |
Junior Member |
I'm sure I already posted a topic asking for help with this but my control panel seems to think I have no posts!
I'm working on a Firefox add-on in Eclipse. To deploy and test the add-on I need to zip up a set of files and change the file extension of the zip file to '.xpi' - similar to how a Java .jar file is actually a zip archive.
I've never used any kind of customised build process in any projects I've worked on in the past - it's always been a case of hitting compile and whichever IDE I happen to be using takes care of the rest. For this project obviously there isn't such an option but I figured it can't be too hard to set up a custom build process and hopefully integrate it with eclipse.
Can anyone make any recommendations on how I can set up a customised build process to selectively zip up a set of files in my project and rename the resulting zip archive to have a .xpi extension?
[Updated on: Thu, 21 April 2011 08:54] Report message to a moderator
Re: Zipping up files to "build" a project [message #666641 is a reply to message #666594] |
Thu, 21 April 2011 12:17 |
> .zip archive.
> with eclipse.
I'd write an ant script in the root of my project. While not a good
learning tool for ant,
http://www.javahotchocolate.com/tutorials/apache-ant.html will show how
examples of using it from Eclipse.
FUDForum. Page generated in 0.07900 seconds
