Re: is there any row size limit on crossTab in Birt reports [message #666339 is a reply to message #666095] |
Wed, 20 April 2011 02:34 |
Vijay,
I believe the team test with 1 million rows. See this bug.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=291714
Any chance you can create a report we can run and test?
Jason
On 4/19/2011 2:23 AM, vijay kumar wrote:
> I am facing one problem while running my birt report. i have a crosstab
> that displays data. it was working fine till yesterday. i have noticed
> one problem that if result row size is more than 4000 i am getting
> "Retrieving binding data error "
> how can i resolve this problem? can some one help me.
> thank you in advance.
> Thank you
> vijay kumar bolisetti
Re: is there any row size limit on crossTab in Birt reports [message #677189 is a reply to message #676952] |
Tue, 07 June 2011 16:46 |
Vijay,
Any chance you could just add a design that uses the csv as a data
source and create the report with the problem? I am not sure where you
are dragging the data items.
Jason
On 6/7/2011 1:16 AM, vijay kumar wrote:
> Hi Json,
> i am sorry in replying late. here is the scenario where you will face the problem. i hava attached my table data here in both excel and csv format. i have used Mysql as DB. you can export the data in to your local DB.
> First create a table with any name in your local data base and insert the rows from excel to table. These are the fields you will see them in table"operation operation_name activity_name AccountingYear monthName MonthId Quantity UnitName " . Define the data source, data set and cross tab in your design. Except quantity reaming fields are groups. I have dragged the monthId and monthname above the Quantity measure header in crosstab. This finishes my cross tab design.
> Next i try to review it will work but you need to run through View Report On Web viewer. At the end of the page you will see the "Retrieving binding data error ".
> Can you try this out and tell me how to overcome this error.
> Thank you
Re: is there any row size limit on crossTab in Birt reports [message #691540 is a reply to message #691398] |
Fri, 01 July 2011 17:11 |
I am not sure what version of BIRT is in MyEclipse 7.5, but here is the
report in BIRT 2.5.2.
Jason
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.21"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version
2.5.2.v20100208 Build <2.5.2.v20100210-0630></property>
<html-property name="description">Creates a blank report with no
predefined content.</html-property>
<list-property name="userProperties">
<structure>
<property name="name">salesbydate.dsOrders.x</property>
<property name="type">integer</property>
<property name="isVisible">false</property>
</structure>
<structure>
<property name="name">salesbydate.dsOrders.y</property>
</structure>
<structure>
<property
name="name">salesbydate.ProductGroup.NewTabularHierarchy.x</property>
</structure>
<structure>
<property
name="name">salesbydate.ProductGroup.NewTabularHierarchy.y</property>
</structure>
<structure>
<property name="name">salesbydate.dsOrders.width</property>
</structure>
<structure>
<property name="name">salesbydate.dsOrders.height</property>
</structure>
</list-property>
<property name="salesbydate.dsOrders.x">251</property>
<property name="salesbydate.dsOrders.y">47</property>
<property
name="salesbydate.ProductGroup.NewTabularHierarchy.x">39</property>
<property
name="salesbydate.ProductGroup.NewTabularHierarchy.y">69</property>
<property name="salesbydate.dsOrders.width">150</property>
<property name="salesbydate.dsOrders.height">200</property>
<property name="units">in</property>
<text-property name="displayName">Blank Report</text-property>
<property name="iconFile">/templates/blank_report.gif</property>
<property name="layoutPreference">auto layout</property>
<data-sources>
<oda-data-source
extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source"
id="6">
<property
name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver</property>
<property name="odaURL">jdbc:classicmodels:sampledb</property>
<property name="odaUser">ClassicModels</property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet"
name="customers" id="8">
<list-property name="columnHints">
<structure>
<property name="columnName">CUSTOMERNUMBER</property>
<text-property
name="displayName">CUSTOMERNUMBER</text-property>
</structure>
<structure>
<property name="columnName">CUSTOMERNAME</property>
<text-property
name="displayName">CUSTOMERNAME</text-property>
</structure>
<structure>
<property name="columnName">CONTACTLASTNAME</property>
<text-property
name="displayName">CONTACTLASTNAME</text-property>
</structure>
<structure>
<property name="columnName">CONTACTFIRSTNAME</property>
<text-property
name="displayName">CONTACTFIRSTNAME</text-property>
</structure>
<structure>
<property name="columnName">PHONE</property>
<text-property name="displayName">PHONE</text-property>
</structure>
<structure>
<property name="columnName">ADDRESSLINE1</property>
<text-property
name="displayName">ADDRESSLINE1</text-property>
</structure>
<structure>
<property name="columnName">ADDRESSLINE2</property>
<text-property
name="displayName">ADDRESSLINE2</text-property>
</structure>
<structure>
<property name="columnName">CITY</property>
<text-property name="displayName">CITY</text-property>
</structure>
<structure>
<property name="columnName">STATE</property>
<text-property name="displayName">STATE</text-property>
</structure>
<structure>
<property name="columnName">POSTALCODE</property>
<text-property
name="displayName">POSTALCODE</text-property>
</structure>
<structure>
<property name="columnName">COUNTRY</property>
<text-property
name="displayName">COUNTRY</text-property>
</structure>
<structure>
<property
name="columnName">SALESREPEMPLOYEENUMBER</property>
<text-property
name="displayName">SALESREPEMPLOYEENUMBER</text-property>
</structure>
<structure>
<property name="columnName">CREDITLIMIT</property>
<text-property
name="displayName">CREDITLIMIT</text-property>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">CUSTOMERNUMBER</property>
<property name="dataType">integer</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">CUSTOMERNAME</property>
<property name="dataType">string</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">CONTACTLASTNAME</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">CONTACTFIRSTNAME</property>
</structure>
<structure>
<property name="position">5</property>
<property name="name">PHONE</property>
</structure>
<structure>
<property name="position">6</property>
<property name="name">ADDRESSLINE1</property>
</structure>
<structure>
<property name="position">7</property>
<property name="name">ADDRESSLINE2</property>
</structure>
<structure>
<property name="position">8</property>
<property name="name">CITY</property>
</structure>
<structure>
<property name="position">9</property>
<property name="name">STATE</property>
</structure>
<structure>
<property name="position">10</property>
<property name="name">POSTALCODE</property>
</structure>
<structure>
<property name="position">11</property>
<property name="name">COUNTRY</property>
</structure>
<structure>
<property name="position">12</property>
<property
name="name">SALESREPEMPLOYEENUMBER</property>
</structure>
<structure>
<property name="position">13</property>
<property name="name">CREDITLIMIT</property>
<property name="dataType">float</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<structure>
<property name="nativeName">CUSTOMERNUMBER</property>
<property name="nativeDataType">4</property>
</structure>
<structure>
<property name="nativeName">CUSTOMERNAME</property>
<property name="nativeDataType">12</property>
</structure>
<structure>
<property name="nativeName">CONTACTLASTNAME</property>
</structure>
<structure>
<property name="nativeName">CONTACTFIRSTNAME</property>
</structure>
<structure>
<property name="nativeName">PHONE</property>
</structure>
<structure>
<property name="nativeName">ADDRESSLINE1</property>
</structure>
<structure>
<property name="nativeName">ADDRESSLINE2</property>
</structure>
<structure>
<property name="nativeName">CITY</property>
</structure>
<structure>
<property name="nativeName">STATE</property>
</structure>
<structure>
<property name="nativeName">POSTALCODE</property>
</structure>
<structure>
<property name="nativeName">COUNTRY</property>
</structure>
<structure>
<property name="name">SALESREPEMPLOYEENUMBER</property>
<property
name="nativeName">SALESREPEMPLOYEENUMBER</property>
</structure>
<structure>
<property name="nativeName">CREDITLIMIT</property>
<property name="nativeDataType">8</property>
</structure>
</list-property>
<xml-property name="queryText"><![CDATA[select *
from customers]]></xml-property>
<xml-property name="designerValues"><![CDATA[<?xml
version="1.0" encoding="UTF-8"?>
<model:DesignValues
xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design"
xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
<Version>1.0</Version>
<design:ResultSets derivedMetaData="true">
<design:resultSetDefinitions>
<design:resultSetColumns>
<design:resultColumnDefinitions>
<design:attributes>
<design:name>CUSTOMERNUMBER</design:name>
<design:position>1</design:position>
<design:nativeDataTypeCode>4</design:nativeDataTypeCode>
<design:precision>10</design:precision>
<design:scale>0</design:scale>
<design:nullability>Nullable</design:nullability>
<design:uiHints>
<design:displayName>CUSTOMERNUMBER</design:displayName>
</design:uiHints>
</design:attributes>
<design:usageHints>
<design:label>CUSTOMERNUMBER</design:label>
<design:formattingHints>
<design:displaySize>11</design:displaySize>
</design:formattingHints>
</design:usageHints>
</design:resultColumnDefinitions>
<design:attributes>
<design:name>CUSTOMERNAME</design:name>
<design:position>2</design:position>
<design:nativeDataTypeCode>12</design:nativeDataTypeCode>
<design:precision>50</design:precision>
<design:uiHints>
<design:displayName>CUSTOMERNAME</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>CUSTOMERNAME</design:label>
<design:displaySize>50</design:displaySize>
<design:attributes>
<design:name>CONTACTLASTNAME</design:name>
<design:position>3</design:position>
<design:uiHints>
<design:displayName>CONTACTLASTNAME</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>CONTACTLASTNAME</design:label>
<design:attributes>
<design:name>CONTACTFIRSTNAME</design:name>
<design:position>4</design:position>
<design:uiHints>
<design:displayName>CONTACTFIRSTNAME</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>CONTACTFIRSTNAME</design:label>
<design:attributes>
<design:name>PHONE</design:name>
<design:position>5</design:position>
<design:uiHints>
<design:displayName>PHONE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>PHONE</design:label>
<design:attributes>
<design:name>ADDRESSLINE1</design:name>
<design:position>6</design:position>
<design:uiHints>
<design:displayName>ADDRESSLINE1</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>ADDRESSLINE1</design:label>
<design:attributes>
<design:name>ADDRESSLINE2</design:name>
<design:position>7</design:position>
<design:uiHints>
<design:displayName>ADDRESSLINE2</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>ADDRESSLINE2</design:label>
<design:attributes>
<design:name>CITY</design:name>
<design:position>8</design:position>
<design:uiHints>
<design:displayName>CITY</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>CITY</design:label>
<design:attributes>
<design:name>STATE</design:name>
<design:position>9</design:position>
<design:uiHints>
<design:displayName>STATE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>STATE</design:label>
<design:attributes>
<design:name>POSTALCODE</design:name>
<design:position>10</design:position>
<design:precision>15</design:precision>
<design:uiHints>
<design:displayName>POSTALCODE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>POSTALCODE</design:label>
<design:displaySize>15</design:displaySize>
<design:attributes>
<design:name>COUNTRY</design:name>
<design:position>11</design:position>
<design:uiHints>
<design:displayName>COUNTRY</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>COUNTRY</design:label>
<design:attributes>
<design:name>SALESREPEMPLOYEENUMBER</design:name>
<design:position>12</design:position>
<design:uiHints>
<design:displayName>SALESREPEMPLOYEENUMBER</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>SALESREPEMPLOYEENUMBER</design:label>
<design:attributes>
<design:name>CREDITLIMIT</design:name>
<design:position>13</design:position>
<design:nativeDataTypeCode>8</design:nativeDataTypeCode>
<design:uiHints>
<design:displayName>CREDITLIMIT</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>CREDITLIMIT</design:label>
<design:displaySize>22</design:displaySize>
</design:resultSetColumns>
</design:resultSetDefinitions>
</design:ResultSets>
</model:DesignValues>]]></xml-property>
</oda-data-set>
<oda-data-set
name="dsOrders" id="9">
<structure>
<property name="columnName">ORDERNUMBER</property>
<text-property
name="displayName">ORDERNUMBER</text-property>
</structure>
<structure>
<property name="columnName">PRODUCTCODE</property>
<text-property
name="displayName">PRODUCTCODE</text-property>
</structure>
<structure>
<property name="columnName">QUANTITYORDERED</property>
<text-property
name="displayName">QUANTITYORDERED</text-property>
</structure>
<structure>
<property name="columnName">PRICEEACH</property>
<text-property
name="displayName">PRICEEACH</text-property>
</structure>
<structure>
<property name="columnName">ORDERLINENUMBER</property>
<text-property
name="displayName">ORDERLINENUMBER</text-property>
</structure>
<structure>
<property name="columnName">ORDERNUMBER_6</property>
<text-property
</structure>
<structure>
<property name="columnName">ORDERDATE</property>
<text-property
name="displayName">ORDERDATE</text-property>
</structure>
<structure>
<property name="columnName">REQUIREDDATE</property>
<text-property
name="displayName">REQUIREDDATE</text-property>
</structure>
<structure>
<property name="columnName">SHIPPEDDATE</property>
<text-property
name="displayName">SHIPPEDDATE</text-property>
</structure>
<structure>
<property name="columnName">STATUS</property>
<text-property
name="displayName">STATUS</text-property>
</structure>
<structure>
<property name="columnName">COMMENTS</property>
<text-property
name="displayName">COMMENTS</text-property>
</structure>
<structure>
<text-property
</structure>
</list-property>
<structure>
<property name="name">ORDERNUMBER</property>
</structure>
<structure>
<property name="name">PRODUCTCODE</property>
</structure>
<structure>
<property name="name">QUANTITYORDERED</property>
</structure>
<structure>
<property name="name">PRICEEACH</property>
</structure>
<structure>
<property name="name">ORDERLINENUMBER</property>
</structure>
<structure>
<property name="name">ORDERNUMBER_6</property>
</structure>
<structure>
<property name="name">ORDERDATE</property>
<property name="dataType">date</property>
</structure>
<structure>
<property name="name">REQUIREDDATE</property>
</structure>
<structure>
<property name="name">SHIPPEDDATE</property>
</structure>
<structure>
<property name="name">STATUS</property>
</structure>
<structure>
<property name="name">COMMENTS</property>
</structure>
<structure>
</structure>
</list-property>
</structure>
<structure>
<property name="nativeName">ORDERNUMBER</property>
</structure>
<structure>
<property name="nativeName">PRODUCTCODE</property>
</structure>
<structure>
<property name="nativeName">QUANTITYORDERED</property>
</structure>
<structure>
<property name="nativeName">PRICEEACH</property>
</structure>
<structure>
<property name="nativeName">ORDERLINENUMBER</property>
<property name="nativeDataType">5</property>
</structure>
<structure>
</structure>
<structure>
<property name="nativeName">ORDERDATE</property>
<property name="nativeDataType">91</property>
</structure>
<structure>
<property name="nativeName">REQUIREDDATE</property>
</structure>
<structure>
<property name="nativeName">SHIPPEDDATE</property>
</structure>
<structure>
<property name="nativeName">STATUS</property>
</structure>
<structure>
<property name="nativeName">COMMENTS</property>
</structure>
<structure>
</structure>
</list-property>
from CLASSICMODELS.ORDERDETAILS, CLASSICMODELS.ORDERS
where CLASSICMODELS.ORDERS.ORDERNUMBER =
CLASSICMODELS.ORDERDETAILS.ORDERNUMBER
and
CLASSICMODELS.ORDERS.STATUS = 'Shipped']]></xml-property>
<model:DesignValues
<design:attributes>
<design:name>ORDERNUMBER</design:name>
<design:uiHints>
<design:displayName>ORDERNUMBER</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>ORDERNUMBER</design:label>
<design:attributes>
<design:name>PRODUCTCODE</design:name>
<design:uiHints>
<design:displayName>PRODUCTCODE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>PRODUCTCODE</design:label>
<design:attributes>
<design:name>QUANTITYORDERED</design:name>
<design:uiHints>
<design:displayName>QUANTITYORDERED</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>QUANTITYORDERED</design:label>
<design:attributes>
<design:name>PRICEEACH</design:name>
<design:uiHints>
<design:displayName>PRICEEACH</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>PRICEEACH</design:label>
<design:attributes>
<design:name>ORDERLINENUMBER</design:name>
<design:nativeDataTypeCode>5</design:nativeDataTypeCode>
<design:precision>5</design:precision>
<design:uiHints>
<design:displayName>ORDERLINENUMBER</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>ORDERLINENUMBER</design:label>
<design:displaySize>6</design:displaySize>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:name>ORDERDATE</design:name>
<design:nativeDataTypeCode>91</design:nativeDataTypeCode>
<design:uiHints>
<design:displayName>ORDERDATE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>ORDERDATE</design:label>
<design:displaySize>10</design:displaySize>
<design:attributes>
<design:name>REQUIREDDATE</design:name>
<design:uiHints>
<design:displayName>REQUIREDDATE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>REQUIREDDATE</design:label>
<design:attributes>
<design:name>SHIPPEDDATE</design:name>
<design:uiHints>
<design:displayName>SHIPPEDDATE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>SHIPPEDDATE</design:label>
<design:attributes>
<design:name>STATUS</design:name>
<design:uiHints>
FUDForum. Page generated in 0.02543 seconds
