Re: Eclipse Classic on PHP Eclipse [message #665847 is a reply to message #665839] |
Sun, 17 April 2011 03:00 |
On 2011.04.16 15:40, tampe125 wrote:
> hi, i have eclipse for PHP development installed.
> now i'm trying to code an app for Android and, as they said on their
> site, i need Eclipse Classic installed.
> so, what i have to do now?
> i have to reinstall everything? is my PHP installation enough? do i have
> to download new plugins?
> thank you in advance
You're free to install the Android SDK tools in any distro of Eclipse
you like. Sometimes, Eclipse can bog down with too many plug-ins
running, but if you bounce it and don't run the plug-ins you're not
using, they won't load and won't impact it while you run others that you
are using. (Hope that doesn't sound too much like nonsense.)
I personally advise a separate installation, Eclipse IDE for Java
Developers, with just the Android stuff, but many others have no trouble
at all (so they tell me) plugging in all sorts of development options at
once. It's your choice. I've run both Galileo and Helios with Android;
they both work very well.
If you like, you may find some of what's in the following article helpful.
http://www.javahotchocolate.com/tutorials/android.html
Re: Eclipse Classic on PHP Eclipse [message #666224 is a reply to message #665847] |
Tue, 19 April 2011 14:07 |
Eric Rizzo Messages: 3070 Registered: July 2009 |
One more bit of useful information: When you select a new feature to
install (such as the Android tools. ADT), Eclipse will automatically
install any other features that are required. So you should be able to
install ADT into your existing instance of Eclipse, it just might take a
little longer to download/install the parts you're missing.
Eric
FUDForum. Page generated in 0.04449 seconds
