Re: Workspace folder [message #663876 is a reply to message #663867] |
Wed, 06 April 2011 16:57 |
On 06-Apr-11 10:46, Nigel Boyle wrote:
> We have an issue running Lotus Notes 8.5 on a Terminal Server Farm.
> Logging in and out of Server1 is fine. Logging in and out of Server 2 is
> fine.
> However we use a broker that randomly puts a user on either 1 or 2. The
> swapping causes some files in workspace folder ( in a common user drive)
> to be rewritten and slows loading.
> We have written the same data into both rpcinstaller files ; hoping this
> would work but it doesn't :(
> We have tried copying the whole workspace folder and making a unique
> copy from Server 1 and from Server 2. If we then replace the live folder
> with Server 1 copy, Server 1 is fast. If we then replace it with the
> Server 2 copy, Server 2 is fast.
> The problem is we dont want to overwrite the whole workspace folder all
> the time, or any changes made by a user are lost. We would appreciate
> help with knowing which are the key files in the folder to replace and
> make the loading fast
> Thanks :p
I struggle to see how this is an Eclipse issue. Are you certain to be in
the right forum?
FUDForum. Page generated in 0.03641 seconds
