Re: Is there an easy way to upgrade from Classic to EE? [message #662496 is a reply to message #662478] |
Wed, 30 March 2011 20:15 |
Ed Merks Messages: 33140 Registered: July 2009 |
Yes, using the Help->Install New Software you can pull in whatever
features you want from the Helios repository. I use App Engine but I
install only the XML tools, not the full EE package. As needed should
be fine...
Ellen Spertus wrote:
> I installed Eclipse 3.6.1 Classic a while ago and have since added
> software for Android, EGit, etc. Some new software I'm interested in
> (App Engine) recommends using Eclipse EE.
> Is there an easy way to add all of the packages that are included in
> EE but not in Classic, or do I have to select each package
> individually? I found this
> http://www.eclipse.org/downloads/moreinfo/compare.php (although the
> http://www.eclipse.org/epp/content.php seems not to include Classic).
> Or should I just ignore the installation advice and install packages
> only as needed?
> Thanks.
Ed Merks
FUDForum. Page generated in 0.07229 seconds
