Eclipse won't start (missing a file) [message #658975] |
Thu, 10 March 2011 15:34 |
D. Alvarado Messages: 91 Registered: July 2009 |
Member |
I'm using Eclipse Galileo for Mac 10.6.3. When I try and start Eclipse, it does not start and shows me the message,
An error has occurred.
See the log file /Users/davea/projects/LVCVA/LVCVA/lvcva_tomcat/sandboxes/lvc va-DEV-checkout/Technology/Code/htdocs/.metadata/.log
The log file reveals ...
!ENTRY org.eclipse.core.resources 4 4 2011-03-09 16:39:03.834
!MESSAGE Exception loading preferences from: /CM Star Team/.settings/org.eclipse.jdt.core.prefs.
!STACK 1
org.eclipse.core.runtime.CoreException: File not found: /Users/davea/projects/LVCVA/LVCVA/lvcva_tomcat/sandboxes/lvc va-DEV-checkout/Technology/Code/htdocs/CM Star Team/.settings/org.eclipse.jdt.core.prefs.
at org.eclipse.core.internal.filesystem.Policy.error(Policy.jav a:55)
at org.eclipse.core.internal.filesystem.local.LocalFile.openInp utStream(LocalFile.java:371)
at org.eclipse.core.internal.localstore.FileSystemResourceManag er.read(FileSystemResourceManager.java:667)
at org.eclipse.core.internal.resources.File.getContents(File.ja va:288)
at org.eclipse.core.internal.resources.ProjectPreferences.load( ProjectPreferences.java:457)
at org.eclipse.core.internal.preferences.EclipsePreferences.cre ate(EclipsePreferences.java:307)
at org.eclipse.core.internal.preferences.EclipsePreferences.get Child(EclipsePreferences.java:412)
at org.eclipse.core.internal.preferences.EclipsePreferences.int ernalNode(EclipsePreferences.java:541)
at org.eclipse.core.internal.preferences.EclipsePreferences.nod e(EclipsePreferences.java:669)
at org.eclipse.core.resources.ProjectScope.getNode(ProjectScope .java:67)
at org.eclipse.jdt.internal.core.JavaProject.getEclipsePreferen ces(JavaProject.java:1416)
at org.eclipse.jdt.internal.core.JavaProject.getOption(JavaProj ect.java:1585)
at org.eclipse.jdt.internal.core.PackageFragmentRoot.computeFol derChildren(PackageFragmentRoot.java:225)
at org.eclipse.jdt.internal.core.PackageFragmentRoot.computeChi ldren(PackageFragmentRoot.java:193)
at org.eclipse.jdt.internal.core.JavaProjectElementInfo.initial izePackageNames(JavaProjectElementInfo.java:252)
at org.eclipse.jdt.internal.core.JavaProjectElementInfo.getProj ectCache(JavaProjectElementInfo.java:225)
at org.eclipse.jdt.internal.core.JavaProject.getProjectCache(Ja vaProject.java:1841)
at org.eclipse.jdt.internal.core.JavaProjectElementInfo.newName Lookup(JavaProjectElementInfo.java:309)
at org.eclipse.jdt.internal.core.JavaProject.newNameLookup(Java Project.java:2264)
at org.eclipse.jdt.internal.core.SearchableEnvironment.<init>(SearchableEnvironment.java:57)
at org.eclipse.jdt.internal.core.SearchableEnvironment.<init>(SearchableEnvironment.java:64)
at org.eclipse.jdt.internal.core.CancelableNameEnvironment.<init >(CancelableNameEnvironment.java:26)
at org.eclipse.jdt.internal.core.CompilationUnitProblemFinder.p rocess(CompilationUnitProblemFinder.java:169)
at org.eclipse.jdt.internal.core.CompilationUnitProblemFinder.p rocess(CompilationUnitProblemFinder.java:262)
at org.eclipse.jdt.internal.core.ReconcileWorkingCopyOperation. makeConsistent(ReconcileWorkingCopyOperation.java:190)
at org.eclipse.jdt.internal.core.ReconcileWorkingCopyOperation. executeOperation(ReconcileWorkingCopyOperation.java:89)
at org.eclipse.jdt.internal.core.JavaModelOperation.run(JavaMod elOperation.java:728)
at org.eclipse.jdt.internal.core.JavaModelOperation.runOperatio n(JavaModelOperation.java:788)
at org.eclipse.jdt.internal.core.CompilationUnit.reconcile(Comp ilationUnit.java:1266)
at org.eclipse.jdt.internal.ui.text.java.JavaReconcilingStrateg y.reconcile(JavaReconcilingStrategy.java:126)
at org.eclipse.jdt.internal.ui.text.java.JavaReconcilingStrateg y.access$0(JavaReconcilingStrategy.java:108)
at org.eclipse.jdt.internal.ui.text.java.JavaReconcilingStrateg y$1.run(JavaReconcilingStrategy.java:89)
That file got deleted from my system. Does anyone know how to force Eclipse to start anyway? - Dave
FUDForum. Page generated in 0.07542 seconds
