How to Differentiate The Type of Change (i.e., normal, or undo) using IUndoManagerListener [message #658028] |
Sat, 05 March 2011 08:48 |
Kivanc Muslu Messages: 153 Registered: November 2010 |
Hi all,
I am trying to use IUndoListener to get notified of the changes and undoes applied workspace wide. It generally works as it should, however I need to somehow match a change that is performed to an undo that is performed (if any) if they represent the same action.
i.e., I have a compilation error because my file in stays in default package however, in the .java file I have package foo; declaration. I click on the quick fix and choose 'move ... to package 'foo''. This creates an aboutToPerformChange(...) action and a changePerformed(...) action. Let's say that after this point I clicked undo (cmd+z), this also creates 2 actions (of course different). How can I understand that the first action is a normal change and the second one represents an undo?
My current implementation of the listener (to better understand what is going on is:
import org.eclipse.ltk.core.refactoring.Change;
import org.eclipse.ltk.core.refactoring.CompositeChange;
import org.eclipse.ltk.core.refactoring.IUndoManager;
import org.eclipse.ltk.core.refactoring.IUndoManagerListener;
public class QFUsageUndoManagerListener implements IUndoManagerListener
public void undoStackChanged(IUndoManager manager)
public void redoStackChanged(IUndoManager manager)
public void aboutToPerformChange(IUndoManager manager, Change change)
System.out.println("=== About to perform change ===");
printChange(change);
System.out.println("===============================");
System.out.println();
public void changePerformed(IUndoManager manager, Change change)
System.out.println("=== Change performed ===");
System.out.println("========================");
private void printChange(Change change)
if (change instanceof CompositeChange)
for (Change child: ((CompositeChange) change).getChildren())
printChange(child);
else
System.out.println("Change performed class = " + change.getClass());
System.out.println("Change performed = " + change.getName());
and for the above scenario, I get the following print-outs:
// Represents the first change, since composite there are 2 changes.
Change performed class = class org.eclipse.jdt.internal.corext.refactoring.changes.CreatePackageChange
Change performed = Create package
Change performed class = class org.eclipse.jdt.internal.corext.refactoring.changes.MoveCompilationUnitChange
Change performed = Move compilation unit 'All.java' to 'foo'
// I have no idea why there is nothing in this?
// Represents the undo, since composite, there are multiple.
Change performed = Move compilation unit 'All.java' to '(default package)'
Change performed class = class org.eclipse.ltk.core.refactoring.resource.DeleteResourceChange
Change performed = Delete 'Quickfixes/src/foo'
// I have no idea why this is different that aboutToPerformChange(...)
Change performed class = class org.eclipse.ltk.internal.core.refactoring.resource.UndoDeleteResourceChange
Change performed = Restore 'foo'
Some internal questions:
1- Why I get an empty CompositeChange for the actual change in changePerformed(...) action?
2- Why the aboutToPerformChange(...) and changePerformed(...) actions are quite different than each other for the undo?
Other suggestions, solutions are always appreciated.
Thanks in advance, best regards,
FUDForum. Page generated in 0.02826 seconds
