Re: Internal browser fails for JSF - FireFox OK [message #657934 is a reply to message #657924] |
Fri, 04 March 2011 16:30 |
On 04-Mar-11 09:09, thealy@bnl.gov wrote:
> Using Helios SR2 Build id: 20110218-0911.
> [Warning: relatively new to Eclipse]
> Working on a JSF / ICEfaces project and internal browser had been
> working fine when I used "Run As -> on server"
> I started adding code from a text (Core Java ServerFaces) to implement a
> chart renderer that returns a .png image. After some messing with some
> package name issues, I tried to run as normal. The internal browser
> attempts to connect with localhost as shown in the bottom status bar. It
> eventually times out after ~30 seconds.
> If I use an external browser (both FireFox and SeaMonkey) to access the
> URL, it works fine.
> **I did add two updates this morning when prompted on Eclipse start-up.
> Any suggestions appreciated.
> -Terry
Probably better asked in the Eclipse webtools forum.
FUDForum. Page generated in 0.04585 seconds
