Home » Modeling » GMF (Graphical Modeling Framework) » Generated Element IDs (xmi:id)?
Generated Element IDs (xmi:id)? [message #657387] Wed, 02 March 2011 16:21 Go to next message
Conor Missing name is currently offline Conor Missing nameFriend
Hi All,
I was wondering if it was possible to shorten the generated xmi:id that is associated with GMF editor components. I have to process composed models multiple times and need to reduce their size to the absolute minimum. I have already stripped out everything I can from the composed models with a transform with the element ids the last thing to be addressed.
Is there anyway of setting the ids length to be in the region of 2 or 3 characters? (instead of the default of 23 or 24)
Gaff
Re: Generated Element IDs (xmi:id)? [message #657410 is a reply to message #657387] Wed, 02 March 2011 16:52 Go to previous messageGo to next message
Gaff,
IDs need to be unique within a resource. GMF makes heavy use of UUIDs
for that purpose; they're guaranteed to be universally unique.
Certainly it's possible (via XMLResource.setID) for you to assign
different values.
Conor wrote:
> Hi All,
> Gaff
Ed Merks
Re: Generated Element IDs (xmi:id)? [message #723437 is a reply to message #657410] Thu, 08 September 2011 14:45 Go to previous messageGo to next message
chavi   is currently offline chavi Friend
Member
Can you please tell me that how to fetch XMI Id.
I have written following code
import org.eclipse.emf.ecore.EObject;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.xmi.XMLResource;
public class myxmi{
public static String xmiId(EObject x) {
Resource resouce = x.eResource();
if (resouce instanceof XMLResource) {
XMLResource xmlResource = (XMLResource)resouce;
return xmlResource.getID(x);
return "";
But when i call this method as myxmi.xmiId(eobject).How can i fetch this object when i click on a particular component.
Re: Generated Element IDs (xmi:id)? [message #724368 is a reply to message #723437] Mon, 12 September 2011 08:03 Go to previous message
Ralph Gerbig is currently offline Ralph GerbigFriend
to get the XMI id use getProxyID from this class http://publib.boulder.ibm.com/infocenter/rsmhelp/v7r0m0/index.jsp?topic=/org.eclipse.gmf.doc/reference/api/runtime/org/eclipse/gmf/runtime/emf/core/util/EMFCoreUtil.html.
Ralph
Previous Topic:Semantics
Next Topic:Printing GenModel Diagram Textually
Current Time: Thu Feb 25 09:21:19 GMT 2021
Powered by FUDForum. Page generated in 0.01689 seconds
