Make Eclipse not to follow symbolic links [message #657360] |
Wed, 02 March 2011 14:56 |
No real name Messages: 1 Registered: March 2011 |
Junior Member |
Hello forum.
[Debian Ubuntu OS]
In my project I work with different version of the same project. I've to work with branches or special versions of the trunk. I will not discuse this. It's stupid, but with load of work i can't change it right now.
The structure is mostly the same. I don't want to make a new workspace for all this projects.
Therefore I create a symbolic link
ln -s trunk current
The problem, Eclipse follow the link and dissolving it even if I import from the link directory.
If I first mv trunk to current:
mv trunk current
then import the directory and then revert the changes:
mv current trunk
ln -s trunk current
all works fine. I'm free to change the project state by
rm current
ln -s branch_XYZ current
but this is a silly solution.
Are the any build in solutions for this use case.
TIA
Holger
FUDForum. Page generated in 0.02794 seconds
