Use directly internal Antlr Parser without Guice [message #656540] |
Sat, 26 February 2011 16:22 |
Jake Messages: 21 Registered: November 2010 |
Junior Member |
Hi, I've developed an IDE for a general purpose language.
The actual parser it's a recursive descent hand written.
I would substitute the actual parser with an auto generated one, and I
firstly try using the ResourceSet mechanism, but the problem is that the
bootstrap of injectors made the process slow, like two or three seconds
profiling the code.
My question is: can I use directly my InternaJolieParser, removing the
use of Guice and hacking the code (istantiatin old style the Grammar
Access)? It is extremely hard? Thank you very much
[Updated on: Sun, 27 February 2011 15:24] Report message to a moderator
Re: USE DIRECTLY INTERNAL ANTLR PARSER WITHOUT GUICE [message #656752 is a reply to message #656540] |
Mon, 28 February 2011 12:33 |
Jan Koehnlein Messages: 760 Registered: July 2009 Location: Hamburg |
Of course you can try, but I'd neither recommend to use the parser
without Guice, as we wire up almost everything using DI, nor hook in a
hand written parser, as we also have a couple of expectations on the
behaviour of the parser, such as error recovery, AST and especially node
model construction, etc. which I think will be extremely hard to fulfill
in your own parser implementation.
The injector should be instantiated only once, and to wait 2 seconds for
a bunch of plugins to be loaded seems to be quite common in Eclipse.
Am 26.02.11 17:22, schrieb Diego Castronuovo:
> Hi, I've developed an IDE for new SOA language (JOLIE).
> profiling the code.
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
Get professional support from the Xtext committers at www.typefox.io
FUDForum. Page generated in 0.02971 seconds
