Re: Adding Modeling tool to Eclipse JDT and CDT [message #656565 is a reply to message #656522] |
Sat, 26 February 2011 20:07 |
Ed Merks Messages: 33140 Registered: July 2009 |
The various packages are essentially subsets of the complete set of all
features/bundles available in the helios repository. Given any
installation of any package, you should be able to add/install whatever
features you want to combine. The installer is smart, and will install
any dependencies needed for the features you select.
There are no fees for using anything you fetch from Eclipse
hpng wrote:
> Hello:
> I have yet to install Eclipse.
> I want to have the following in an IDE.
> 1)Java
> http://www.eclipse.org/downloads/packages/eclipse-ide-java-d evelopers/heliossr2
> 2)C++/C
> http://www.eclipse.org/downloads/packages/eclipse-ide-cc-lin ux-developers-includes-incubating-components/heliossr2
> 3)Modeling
> http://www.eclipse.org/downloads/packages/node/508
> Does this modeling tool has code generation?
> The forum link below discuss how to combine (1) and (2) above.
> http://www.eclipse.org/forums/index.php?t=msg&goto=55713 8&S=6dd6e4d0e1caa4566f3637a1759f36c7
> Question: Do I do the "same" procedure to include (3) into the IDE?
> "Same" means this:
> "I think that you can install one of the "pre-builded" IDEs for
> example Eclipse for Java Developers and then go to Help -> Install new
> software and insert the repositorie url of the other project."
> as discussed in the above forum thread (link).
> I also looked at Eclipse Classic at this link:
> http://www.eclipse.org/downloads/packages/node/506
> which has this vague description:
> "The classic Eclipse download: the Eclipse Platform, Java Development
> Tools, and Plug-in Development Environment, including source and both
> user and programmer documentation."
> I am not sure what "Plug-in Development Environment" consists of?
> I am not sure if eclipse classic has all the above three items such
> that I only have to install it as opposed to the above three IDEs.
> Alternative solution:
> From this link:
> http://www.eclipse.org/forums/index.php?t=msg&goto=65398 7&S=a40eb4d9a547ef83c5f82ce4d4f6eef1
> It appears I can install Eclipse for Java and C++ in its own separate
> folders, e.g. folder name like so : EclipseJDT, and EclipseCDT.
> However, can I install the modeling tool, item (3) above, into each IDE?
> Where is the link for the modeling tool plug-in?
> Is there a license fee for using JEE on distributed systems or servers?
> Please advice..
> Cheers....
Ed Merks
Re: Adding Modeling tool to Eclipse JDT and CDT [message #656863 is a reply to message #656565] |
Mon, 28 February 2011 19:47 |
hpng Mising name Messages: 9 Registered: February 2011 |
Junior Member |
Here is probably what i should do:
Install each instant of eclipse IDE, say Eclipse CDT and JDT
in two folders, namely EclipseJDT folder, and EclipseCDT folder.
I have installed JDT and going thru its tutorial. Great IDE!
Then i will install Eclipse CDT, again in separate folder.
Since you mention Eclipse installer is smart,
how do I prevent Eclipse CDT from installing it into Eclipse JDt a as a plug-in?
Question about Java EE.
Say I develop Java EE apps, and put it on a server with java EE Virtual Machine,
do I have to pay Oracle licensing fee to use its JEE VM?
is there a GNU / GPL JEE VM or similar FREE ( as in Freedom and no fees)?
Cheers.
[Updated on: Mon, 28 February 2011 19:48] Report message to a moderator
Re: Adding Modeling tool to Eclipse JDT and CDT [message #656907 is a reply to message #656883] |
Mon, 28 February 2011 22:56 |
I don't know of one. It's not really an Eclipse question is it?
>> Virtual Machine,
>> do I have to pay Oracle licensing fee to use its JEE VM? is there a
> No.
> is the answer "NO" apply to both questions above?
Ed Merks
FUDForum. Page generated in 0.09540 seconds
