Home » Newcomers » Newcomers » Unable to import Launch Configurations
Unable to import Launch Configurations [message #653928] Fri, 11 February 2011 17:21 Go to next message
I'm using Eclipse 3.6.1 with several workspaces.
I've created a few External tool configurations with complex commmand lines that I would like to use with projects in other workspaces.
I can use Export to export these launch configurations, but in the other workspaces, Import just won't allow me to import them.
I select the directory they are in, and it doesn't show anything to import.
Re: Unable to import Launch Configurations [message #654239 is a reply to message #653928] Mon, 14 February 2011 12:05 Go to previous messageGo to next message
When you're editing a Launch Configuration, look at the Common tab,
where you'll find an option for storing the config file in a "shared"
location. I usually put them in a directory inside the project and then
check that in to source control with the rest of the project files. That
way, whenever the project is checked out into a workspace, those
launches will show up automatically.
Eric
Re: Unable to import Launch Configurations [message #654242 is a reply to message #654239] Mon, 14 February 2011 12:35 Go to previous message
While that is useful information, it doesn't seem to have anything to do with my question.
WHY can't I import a launch configuration that I exported from another project.
Previous Topic:Export Product problem
Next Topic:How to run exclipse app on mobile phone
Current Time: Fri Nov 07 08:43:58 EST 2025
Powered by FUDForum. Page generated in 0.11202 seconds
