when and how code assist scans classpath etc? [message #653497] |
Thu, 10 February 2011 00:29 |
No real name Messages: 1 Registered: February 2011 |
Junior Member |
Like most people on Windows I ended up with a few versions of JRE including the latest, then installed Eclipse 3.5, then started a J3d project but noticed I had no j3d installed, then installed binaries from java.net that ended up in the JRE that is not the default for Eclipse, then changed the default, unchecked some "hide" from the Preferences even though the default is not to hide deprecated packages like J3D, started a new project and still com.sun.j3....nothing.
Now, packages like this end up in jre/lib/ext, isn't code assist scanning the JRE for new packages? Is code assist scanning also everything I may choose to include in the Classpath, or perhaps only when the the directory name is edited, but not the contents? And where does the information for deprecated/restricted/whatever special categories comes from? Is it simply some masterlist grepped from Java's latest release notes?
FUDForum. Page generated in 0.07951 seconds
