| Change double-click selection behavior in editor. [message #652961] |
Mon, 07 February 2011 13:45  |
Hello all!
My observations:
- When we double-click on an element in source code Eclipse selects identifier, keyword or code block.
- Then when we quickly enough do third click it extends selection a little bit, most of the time to select whole line (although this depends on what was previously selected by double-clicking).
- When we do fourth click it resets selection.
What would be perfect though is being able to override this behavior to perform "Select Enclosing Element" command on third, fourth, fifth and subsequent clicks.
I understand that I can use "Shift+Alt+Up" for doing that, but I think it would be much better to do it with a mouse. At least why the heck it selects a whole line on the third click? I've never been able to found any use for that. But that's my IMHO, of course.
Anyway, could you share your suggestions for achieving what I described above?
| Re: Change double-click selection behavior in editor. [message #653019 is a reply to message #652961] |
Mon, 07 February 2011 21:33  |
On 2/8/2011 12:15 AM, bobby wrote:
> Hello all!
> My observations:
> identifier, keyword or code block. Then when we quickly enough do third
> double-clicking).
> subsequent clicks.
What if you wanted to copy the whole line :) I think this is a pretty
standard text editor behavior.
> above?
FUDForum. Page generated in 0.09119 seconds
