Home » Modeling » TMF (Xtext) » Guava vs. Google Collections
Guava vs. Google Collections [message #652860] |
Mon, 07 February 2011 12:25 |
Franz-Stefan Mising name Messages: 12 Registered: December 2010 |
Junior Member |
Hi, I want to use functionality (in particular, the method Sets.cartesianProduct(...)) from Google's Guava in my Xtext project.
When running my application with the latest Guava .jar file in my Build Path, I get a security exception:
java.lang.SecurityException: class "com.google.common.collect.ReferenceMap"'s signer information does not match signer information of other classes in the same package
To circumvent that problem, I removed the com.google.common plugin from my PDE Target Platform.
I expected this to work as Guava claims: "Guava contains a strictly compatible superset of the old, deprecated Google Collections Library. You should not use that library" [1].
However, this causes another problem:
java.lang.ClassNotFoundException: com.google.common.collect.ReferenceMap
Some web search reveals that the ReferenceMap was apparently kicked out of Google Collections at some point [2], thus, it's also not part of Guava.
So, does anybody have a hint on how I can get Guava into my Xtext project?
Is there maybe a version of Xtext that is already dependent on Guava rather than the outdated Google Collections?
[1] http://code.google.com/p/guava-libraries/
[2] http://stackoverflow.com/questions/2045618/mapmaker-and-refe rencemap-google-collections
Thank you.
[Updated on: Mon, 07 February 2011 12:29] Report message to a moderator
Re: Guava vs. Google Collections [message #653838 is a reply to message #652860] |
Fri, 11 February 2011 13:18 |
Sven Efftinge Messages: 1823 Registered: July 2009 |
We haven't migrated ti Guava, since it is not available in a >= 1.x
version. We use require bundle dependencies so you would have to
replace the com.google.collect bundle shipped with Xtext with a bundle
containing the guava sources (but with a bundle name com.google.collect).
Sven
Am 2/7/11 1:25 PM, schrieb Franz-Stefan:
> [2]
> Thank you.
Need professional support for Xtext or other Eclipse Modeling technologies?
Go to: http://xtext.itemis.com
Twitter : @svenefftinge
Blog : http://blog.efftinge.de
Re: Guava vs. Google Collections [message #654069 is a reply to message #653838] |
Sun, 13 February 2011 23:24 |
Junior Member |
Sven, I'm afraid wrapping Guava in a com.google.collect bundle would not solve the problem:
Xtext depends on some classes that are only contained in version 0.8.0 of com.google.collect, but not in higher versions.
Guava is a proper superset of com.google.collect version 1.0.0. Thus, Guava does not contain all classes that Xtext depends on.
In particular, two of the classes missing in version 1.0.0 (and thus in Guava) are:
> com.google.common.base.ReferenceType
Exactly these classes are used, e.g., in EcoreUtil2 though (see the last two 'import' statements).
So, the only solution to permanently allow Xtext to be used together with Guava seems to be the removal of the dependencies on those classes, i.e., to substitute the dependency on version 0.8.0 by 1.0.0 or even by Guava itself.
Regards, Franz-Stefan.
Re: Guava vs. Google Collections [message #654119 is a reply to message #654069] |
Mon, 14 February 2011 09:12 |
Sebastian Zarnekow Messages: 3118 Registered: July 2009 |
Hi Franz-Stefan,
you could try to extract the parts of your code that depends on guava
into an own bundle. It should be possible to define appropriate bundle
dependencies with OSGi.
Please note that Xtext 2.0 depends on google.collect 1.0.
Sebastian
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
Am 14.02.11 00:24, schrieb Franz-Stefan:
> solve the problem:
> Guava) are:
> http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.tmf/org .eclipse.xtext/plugins/org.eclipse.xtext/src/org/eclipse/xte xt/EcoreUtil2.java?root=Modeling_Project&view=co
> Guava itself.
Current Time: Wed Apr 24 22:35:00 GMT 2024
Powered by FUDForum. Page generated in 0.02878 seconds
