Home » Newcomers » Newcomers » Problem debugging PHP(the debug sesion could not be started please make sure that the debugger is properly configured an a php.ini directive)
Problem debugging PHP [message #652628] Fri, 04 February 2011 13:37 Go to next message
I was running eclipse with a zend php debugger on my old laptop without a hitch. I was just running simple scripts outputting to the debug window, as I couldn't get the Debug as PHP Web Page feature to work.
I got a new windows 64 bit laptop and I installed eclipse-php-helios-SR1-win32-x86_64, from the eclipse website yesterday. I set my PHP executable path to a php.exe in a Zend Studio 8.0.0 folder. (Eclipse found this for me when hitting the "search" button.)
Under installed debuggers, a Zend debugger on Port 10000 shows up, along with XDebug on Port 9000.
I have tinkered for innumerable hours trying to get a simple debug to run, but keep getting....
the debug sesion could not be started please make sure that the debugger is properly configured an a php.ini directive.
Help?!?!?
[Updated on: Fri, 04 February 2011 13:37] by Moderator
Re: Problem debugging PHP [message #652629 is a reply to message #652628] Fri, 04 February 2011 13:46 Go to previous messageGo to next message
This seems a bit offtopic for a Newcomers forum.
With that being said, you may have more luck asking on the PHP forum or on one of the Zend forums.
Denis
No Real Name wrote on Fri, 04 February 2011 13:37
Help?!?!?
Re: Problem debugging PHP [message #652635 is a reply to message #652628] Fri, 04 February 2011 14:19 Go to previous message
OK, thanks. Will try to post in the correct place.
Previous Topic:Highlight Variable
Next Topic:Downloading Eclipse
Current Time: Fri Nov 07 08:30:35 EST 2025
Powered by FUDForum. Page generated in 0.11605 seconds
