Home » Newcomers » Newcomers » install all parts offline I have most parts done Missing (platform tools)
install all parts offline I have most parts done Missing (platform tools) [message #652615] Fri, 04 February 2011 12:41 Go to next message
I have been learning how to use this program at home and now Trying to do a little at work with a laptop that has no Internet connection. I have so far been able to install the SDK and one platform (2.2) When I try and make a new project Eclipse tells me that the aapt is missing and to look at (c:\program files\android\android-sdk-windows\platform tools\aapt.exe). I'm missing the (platform tools) folder all together. I have not yet found away to get this offline.
I also get a error that (R can not be resolved to a variable)
Re: install all parts offline I have most parts done Missing (platform tools) [message #652618 is a reply to message #652615] Fri, 04 February 2011 12:55 Go to previous messageGo to next message
WOW I'm past the missing platform-tools used this http://dl-ssl.google.com/android/repository/repository.xml
posted by Quakeboy here
I found the platform-tools download same way I found the 2.2 platform
Any how now I'm at R can not be resolved to a variable
Re: install all parts offline I have most parts done Missing (platform tools) [message #652646 is a reply to message #652615] Fri, 04 February 2011 14:57 Go to previous messageGo to next message
You're asking a lot. Better to take some time connected to the Internet
to get it right, then you can work disconnected.
Check out http://www.javahotchocolate.com/tutorials/android.html which
has a link to the best tutorial. If you can get through that while
connected, you're sure to be up and going.
Hope this helps.
Re: install all parts offline I have most parts done Missing (platform tools) [message #652647 is a reply to message #652618] Fri, 04 February 2011 15:08 Go to previous messageGo to next message
> posted by Quakeboy
> http://qdevarena.blogspot.com/2010/05/download-android-sdk-s tandalone-for.html
Oh, yeah, that's a common problem (of perception only). Look at
http://www.javahotchocolate.com/tutorials/android.html#r-jav a
for the answer to that.
Re: install all parts offline I have most parts done Missing (platform tools) [message #652714 is a reply to message #652615] Sat, 05 February 2011 15:06 Go to previous messageGo to next message
i think you cant do this,you need an internet connection in the first instance to install and download the different platforms then you need this connection in a "live "way to update.Ive been trying to do this off line you can install the eclipse program but you need an internet connection,not for the adt plug in,or sdk tools .
Re: install all parts offline I have most parts done Missing (platform tools) [message #652950 is a reply to message #652714] Mon, 07 February 2011 12:38 Go to previous message
No got it working by downloading the parts I link to before and unzipping them to the required folder. As for the
I think I'm pass that as well. Created a new project with a NEW NAME and all is well. New name seemed to be the key. Even deleting the old project didn't seem to help.
Previous Topic:Link local repository files to website
Next Topic:What is the package naming convention?
Current Time: Sat Nov 08 14:50:28 EST 2025
Powered by FUDForum. Page generated in 0.09971 seconds
