A question about adding AspectJ nature to a plugin project programmatically [message #65468] |
Fri, 26 May 2006 10:03  |
Originally posted by: sbederml.gmail.com
I use AJDTUtils.addAspectJNature(project) for this, but the problem is
that it asks the user for confirmation and opens the dependencies view
of the plugin. So, if I want to do it for 5 projects programmatically,
it becomes very not convenient.
Is there a way to add AspectJ project to a plugin without UI side effects?
Michael
Re: A question about adding AspectJ nature to a plugin project programmatically [message #593971 is a reply to message #65468] |
Fri, 26 May 2006 11:02  |
Yes, AspectJUIPlugin.convertToAspectJProject(), as long as you are using
a recent dev build of AJDT 1.4 (or the source from CVS HEAD).
The plugin manifest will still be opened in the editor as this is a
side-effect of changing the dependencies, but no user interaction is
involved.
Matt.
Re: A question about adding AspectJ nature to a plugin project programmatically [message #594008 is a reply to message #65490] |
Fri, 26 May 2006 14:53  |
It is still not convenient if I use it for adding AspectJ nature to
multiple plugins. Is there a way of doing this without plugin manifest
being open?
Michael
>> effects?
> involved.
> Matt.
FUDForum. Page generated in 0.04257 seconds
