Home » Newcomers » Newcomers » Eclipse IDE Setup for PHP/Zend, Javascript/JQuery, CSS, HTML, XML
Eclipse IDE Setup for PHP/Zend, Javascript/JQuery, CSS, HTML, XML [message #651519] Mon, 31 January 2011 09:09
I would like to setup my Eclipse IDE (Helios 3.6.x) for Web Development and I have been trying to do this for hours now without satisfying results. I was using Eclipse with the Aptana 1.5.x Plugin until now, but it is outdated, painfully slow, has no support for XHTML 1.0 / HTML 5 and CSS 3 and it is not supported any more. Aptana 3.0.0 instead is very buggy and not ready to use.
So I try to set up Eclipse for PHP Developers to get the IDE I need, but there are a lot of problems. The PHP support is good enough: Code completion, errors are detected and highlighted detailed, auto-code-completion and documentation on key up, code outline and custom syntax highlighting. But I can not get working the same things for Javascript / JQuery, HTML and CSS files, errors are shown not or poorly. I tried Eclipse for Javascript Developers, things are are better here with HTML and Javascript (Errors, but no autocompletion), CSS still sucks.
I tried some plugins searching on the internet but nothing seems really to work and most plugins are outdated, too. Does anybody know the right and up to date plugins for this purpose? Or is it just a problem with the settings and I am not able to figure out how to configure it? How can I integrate Eclipse for PHP Developers and Eclipse for Javascript Developers into one installation?
I cannot imagine to be the first one to have this problem, this is such a standard IDE setup for Web Development.
Previous Topic:Tomcat 7
Next Topic:export applet with referenced libraries to jar
Current Time: Thu Nov 06 17:19:28 EST 2025
Powered by FUDForum. Page generated in 0.09643 seconds
