Home » Newcomers » Newcomers » Tomcat 7(Setting up Tomcat 7 for Eclipse Helios (openSuse 11.3))
Tomcat 7 [message #651267] Fri, 28 January 2011 11:20 Go to next message
I'm using Eclipse Helios on openSuse 11.3.
I just installed Tomcat 7 and it works fine.
I added Tomcat 7 to Eclipse by mean of Window -> Preferences -> Servers -> Runtime Environment -> Add.
But I can't achieve Tomcat starts.
Any idea?
I'm newbie in Eclipse and Tomcat, so I'd appreciate details.
Thank you, so much.
[Adrián E. Córdoba]
Re: Tomcat 7 [message #651345 is a reply to message #651267] Sat, 29 January 2011 11:39 Go to previous messageGo to next message
> Any idea?
> Thank you, so much.
> [Adrián E. Córdoba]
It's difficult to help without a lot more details. What are the steps
you followed, at what point did Tomcat not start, what did it say when
it didn't start, etc.?
Re: Tomcat 7 [message #651435 is a reply to message #651345] Sun, 30 January 2011 15:58 Go to previous messageGo to next message
Thank you, Russell, for aswering.
I finish to configure Tomcat for Eclipse.
I copied catalina.policy, server.xml, tomcat-users.xml and web.xml files from "/usr/share/apache-tomcat-7.0.6/conf/" to the Servers folder in the Package Explorer on Eclipse.
And then, change the ports used for Tomcat instance for Eclipse in server.xml file.
That's all.
Thank you again.
[Adrián E. Córdoba]
Re: Tomcat 7 [message #651442 is a reply to message #651435] Sun, 30 January 2011 16:52 Go to previous messageGo to next message
> server.xml file.
> That's all.
> Thank you again.
> [Adrián E. Córdoba]
First, understand that I haven't use Tomcat 7 so far. My experience with
previous versions is that Tomcat is very easy to set up for use with
Eclipse and has so far never involved copying any files whatsoever. I
have on occasion, however, edited server.xml to change from using port
8080 to another.
My experience setting up previous versions of Tomcat is detailed in the
third article of
http://www.javahotchocolate.com/tutorials/eclipse-summary.ht ml
I hope this helps.
If you have deeper Tomcat questions, you may wish to frequent the
eclipse.webtools forum and also read the Tomcat FAQ at
http://wiki.eclipse.org/WTP_Tomcat_FAQ
Re: Tomcat 7 [message #651502 is a reply to message #651442] Mon, 31 January 2011 08:10 Go to previous message
Thank you very much.
Previous Topic:Virgo
Next Topic:Eclipse IDE Setup for PHP/Zend, Javascript/JQuery, CSS, HTML, XML
Current Time: Sat Nov 08 03:00:34 EST 2025
Powered by FUDForum. Page generated in 0.09666 seconds
