| Problem With JUnit in Lesson 6 [message #648975] |
Sun, 16 January 2011 21:32  |
I'm as new as they come to Eclipse. I'm going through the (EXCELLENT!) tutorials, and am having a problem in Lesson 6. I've googled everything I can think of (which probably means I'm not thinking straight) and can find nothing.
In this lesson, we create another test procedure, testToString(). When I tell Eclipse to rerun the test, this new test does not get executed. In the tutorial, all that he does is to rerun the test, there is nothing that would add the new procedure to the tests that should be run. In the package explorer, the new test is clearly seen by Eclipse. It just isn't being run.
I do note that I have JUnit 4 installed, and the tutorial references JUnit 3. That may be irrelevant, but I mention it to be complete.
I'm sure this fix is simple - and probably obvious - but I don't see it.
Thanks in advance to anyone who can help.
---Michael
FUDForum. Page generated in 0.10159 seconds
