Home » Newcomers » Newcomers » Where to file a bug? - Ubuntu JVM Crash using Nebula widgets
Where to file a bug? - Ubuntu JVM Crash using Nebula widgets [message #643518] |
Tue, 07 December 2010 08:52 |
Mark Hoffmann Messages: 113 Registered: July 2009 Location: Jena |
Hi all,
I use nebula CollapsibleButtons, PShelf in an view and CDateTime in a wizard. The view with the collapsible buttons is always visible. If I start the wizard with the CDateTime widget from a menu, the JVM crashes. When I remove the view from my RCP the wizard starts as expected without crash.
The crash happens with Ubuntu Linux 10.4, 10.10 64bit GTK 2.22 Helios SR1 and the CollapsibleButton, CWT, PShelf and CDateTime from CVS HEAD, Sun/Oracle JVM 1.6.22.
Under Windows XP and Gentoo Linux64 with GTK 2.20, Sun/Oracle JVM 1.6.22 the snippet works without crash.
I included an snippet, based on the CollapsibleButtonsSnippet1, that produces the problem at my machine.
Further I attached an excerpt from the JVM crash-log.
I will now try to use the SWT DateTime widget instead of the CDateTime.
My Question is, where should I raise a bug? I filed a post in the nebula newgroup, but got no response, so I try it here.
Mark
SNIPPET:
import java.util.Date;
import org.eclipse.nebula.widgets.cdatetime.CDT;
import org.eclipse.nebula.widgets.cdatetime.CDateTime;
import org.eclipse.nebula.widgets.collapsiblebuttons.CollapsibleButtons;
import org.eclipse.nebula.widgets.collapsiblebuttons.IColorManager;
import org.eclipse.swt.SWT;
import org.eclipse.swt.graphics.Image;
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.layout.GridData;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.program.Program;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Shell;
* @author Nicolas Richeton (nicolas.richeton)
public class CollapsibleButtonsSnippet1 {
Display display = new Display();
Image itemImage24 = new Image(display, Program
.findProgram("jpg").getImageData().scaledTo(24, 24)); //$NON-NLS-1$
Image itemImage16 = new Image(display, Program
.findProgram("jpg").getImageData().scaledTo(16, 16)); //$NON-NLS-1$
Shell shell = new Shell(display);
shell.setSize(400, 400);
shell.setLayout(new FillLayout(SWT.VERTICAL));
Composite c = new Composite(shell, SWT.NONE);
c.setLayout(new FillLayout(SWT.VERTICAL));
CDateTime beginTime = new CDateTime(c, CDT.BORDER | CDT.DROP_DOWN | CDT.TIME_SHORT | CDT.CLOCK_24_HOUR);
beginTime.setSelection(new Date());
Composite inner = new Composite(shell, SWT.NONE);
GridLayout gl = new GridLayout(1, true);
gl.marginBottom = 0;
gl.marginHeight = 0;
gl.marginWidth = 0;
inner.setLayout(gl);
CollapsibleButtons collapsibleButtons = new CollapsibleButtons(inner,
SWT.NONE, IColorManager.SKIN_OFFICE_2007);
collapsibleButtons.setLayoutData(new GridData(GridData.GRAB_VERTICAL
| GridData.FILL_HORIZONTAL | GridData.VERTICAL_ALIGN_END));
for (int i = 0; i < 5; i++) {
collapsibleButtons.addButton("Button "+i, "Tooltip "+i, itemImage24,
itemImage16);
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch())
display.sleep();
display.dispose();
itemImage16.dispose();
itemImage24.dispose();
LOG:
# A fatal error has been detected by the Java Runtime Environment:
# SIGSEGV (0xb) at pc=0x00007f4fcc2ee1e0, pid=2404, tid=139980690405136
# JRE version: 6.0_22-b04
# Java VM: Java HotSpot(TM) 64-Bit Server VM (17.1-b03 mixed mode linux-amd64 )
# Problematic frame:
# C
# If you would like to submit a bug report, please visit:
# http://java.sun.com/webapps/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
--------------- T H R E A D ---------------
Current thread (0x00000000420cc800): JavaThread "main"
siginfo:si_signo=SIGSEGV: si_errno=0, si_code=1 (SEGV_MAPERR), si_addr=0xffffffff908ccba0
Registers:
RAX=0x00007f4fcc2ee1e0, RBX=0xffffffff908ccba0, RCX=0xfffffffffff449a0, RDX=0x0000000000000002
RSP=0x00007f4fcb536b78, RBP=0x00007f4fcb536bb0, RSI=0xffffffff908ccba0, RDI=0x00007f4fcb536bb0
R8 =0x0000000000000010, R9 =0x0000000000000c80, R10=0x00007f4fc75abc5b, R11=0x00007f4fcbe27610
R12=0x00007f4fcb536bb0, R13=0x0000000000000010, R14=0x00007f4fcb536c88, R15=0x00000000420cc800
RIP=0x00007f4fcc2ee1e0, EFL=0x0000000000010202, CSGSFS=0x0000000000000033, ERR=0x0000000000000005
TRAPNO=0x000000000000000e
Top of Stack: (sp=0x00007f4fcb536b78)
0x00007f4fcb536b78: 00007f4fcc2ec852 00007f4fcb536c68
0x00007f4fcb536b88: 00007f4fcb536bb0 00007f4fcb536c88
0x00007f4fcb536b98: 00000000420cc9c8 00007f4f98272408
0x00007f4fcb536ba8: 00007f4f89b3dc17 00000000420cd1b0
0x00007f4fcb536bb8: 00000000420cd1b0 00007f4f98272408
0x00007f4fcb536bc8: 00007f4fcb536c48 00000000420cc800
0x00007f4fcb536bd8: 00007f4fc75abc88 00007f4fcb536c00
0x00007f4fcb536be8: 00000000420cc800 00000000420cd1d0
0x00007f4fcb536bf8: 00000000420cd1d8 00000000420cc800
0x00007f4fcb536c08: 00007f4fcb536c08 0000000000000000
0x00007f4fcb536c18: 00007f4fcb536c88 00007f4f98284970
0x00007f4fcb536c28: 0000000000000000 00007f4f98272408
0x00007f4fcb536c38: 0000000000000000 00007f4fcb536c68
0x00007f4fcb536c48: 00007f4fcb536cd0 00007f4fc75a0a42
0x00007f4fcb536c58: 00007f4f98284728 00007f4fc75a8f18
0x00007f4fcb536c68: 0000000000000010 0000000000000010
0x00007f4fcb536c78: ffffffff908ccba0 00007f4fbcbca958
0x00007f4fcb536c88: 00007f4fbcbca958 00007f4fcb536c90
0x00007f4fcb536c98: 00007f4f99711311 00007f4fcb536dd8
0x00007f4fcb536ca8: 00007f4f99804928 0000000000000000
0x00007f4fcb536cb8: 00007f4f99711960 00007f4fcb536c68
0x00007f4fcb536cc8: 00007f4fcb536dc0 00007f4fcb536e20
0x00007f4fcb536cd8: 00007f4fc75a0a42 0000000000000000
0x00007f4fcb536ce8: 0000000000000000 0000000000000000
0x00007f4fcb536cf8: 0000000000000000 0000000000000000
0x00007f4fcb536d08: 0000000000000000 0000000000000000
0x00007f4fcb536d18: 0000000000000000 0000000000000000
0x00007f4fcb536d28: 0000000000000000 0000000000000000
0x00007f4fcb536d38: 0000000000000000 0000000000000000
0x00007f4fcb536d48: 0000000000000000 0000000000000000
0x00007f4fcb536d58: 0000000000000000 00000000908ccba0
0x00007f4fcb536d68: 00007f4fbcbca958 0000000000000000
Instructions: (pc=0x00007f4fcc2ee1e0)
0x00007f4fcc2ee1d0: 6f 48 83 c6 08 eb 9b 66 0f 1f 84 00 00 00 00 00
0x00007f4fcc2ee1e0: 48 8b 06 48 83 c2 06 48 83 ee 30 48 83 ef 38 e9
Stack: , sp=0x00007f4fcb536b78, free space=3ee0000000000000018k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
C
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j org.eclipse.swt.internal.gtk.OS.memmove(Lorg/eclipse/swt/int ernal/gtk/GtkBorder;JJ)V+0
j org.eclipse.swt.internal.theme.ButtonDrawData.draw(Lorg/ecli pse/swt/internal/theme/Theme;Lorg/eclipse/swt/graphics/GC;Lo rg/eclipse/swt/graphics/Rectangle;)V+817
j org.eclipse.swt.internal.theme.Theme.drawBackground(Lorg/ecl ipse/swt/graphics/GC;Lorg/eclipse/swt/graphics/Rectangle;Lor g/eclipse/swt/internal/theme/DrawData;)V+43
j org.eclipse.nebula.cwt.v.VButtonPainter.paintBackground(Lorg /eclipse/nebula/cwt/v/VControl;Lorg/eclipse/swt/widgets/Even t;)V+244
j org.eclipse.nebula.cwt.v.VControl.paintControl(Lorg/eclipse/ swt/widgets/Event;)V+272
j org.eclipse.nebula.cwt.v.VPanelPainter.paintContent(Lorg/ecl ipse/nebula/cwt/v/VControl;Lorg/eclipse/swt/widgets/Event;)V +27
j org.eclipse.nebula.cwt.v.VControl.paintControl(Lorg/eclipse/ swt/widgets/Event;)V+316
j org.eclipse.nebula.cwt.v.VPanel$1.handleEvent(Lorg/eclipse/s wt/widgets/Event;)V+52
J org.eclipse.swt.widgets.EventTable.sendEvent(Lorg/eclipse/sw t/widgets/Event;)V
j org.eclipse.swt.widgets.Widget.sendEvent(Lorg/eclipse/swt/wi dgets/Event;)V+25
j org.eclipse.swt.widgets.Widget.sendEvent(ILorg/eclipse/swt/w idgets/Event;Z)V+73
j org.eclipse.swt.widgets.Widget.sendEvent(ILorg/eclipse/swt/w idgets/Event;)V+4
j org.eclipse.swt.widgets.Control.gtk_expose_event(JJ)J+192
j org.eclipse.swt.widgets.Composite.gtk_expose_event(JJ)J+42
j org.eclipse.swt.widgets.Canvas.gtk_expose_event(JJ)J+51
j org.eclipse.swt.widgets.Widget.windowProc(JJJ)J+392
j org.eclipse.swt.widgets.Control.windowProc(JJJ)J+223
j org.eclipse.swt.widgets.Display.windowProc(JJJ)J+20
v ~StubRoutines::call_stub
j org.eclipse.swt.internal.gtk.OS._gtk_main_do_event(J)V+0
j org.eclipse.swt.internal.gtk.OS.gtk_main_do_event(J)V+8
j org.eclipse.swt.widgets.Display.eventProc(JJ)J+132
j org.eclipse.swt.internal.gtk.OS._g_main_context_iteration(JZ )Z+0
j org.eclipse.swt.internal.gtk.OS.g_main_context_iteration(JZ) Z+9
j org.eclipse.swt.widgets.Display.readAndDispatch()Z+33
j org.eclipse.jface.window.Window.runEventLoop(Lorg/eclipse/sw t/widgets/Shell;)V+23
j org.eclipse.jface.window.Window.open()I+49
j de.sim.phcl.ui.organizer.handlers.OpenOrganizerWizardHandler .execute(Lorg/eclipse/core/commands/ExecutionEvent;)Ljava/la ng/Object;+71
j org.eclipse.ui.internal.handlers.HandlerProxy.execute(Lorg/e clipse/core/commands/ExecutionEvent;)Ljava/lang/Object;+33
j org.eclipse.core.commands.Command.executeWithChecks(Lorg/ecl ipse/core/commands/ExecutionEvent;)Ljava/lang/Object;+115
j org.eclipse.core.commands.ParameterizedCommand.executeWithCh ecks(Ljava/lang/Object;Ljava/lang/Object;)Ljava/lang/Object; +21
j org.eclipse.ui.internal.handlers.HandlerService.executeComma nd(Lorg/eclipse/core/commands/ParameterizedCommand;Lorg/ecli pse/swt/widgets/Event;)Ljava/lang/Object;+6
j org.eclipse.ui.internal.handlers.SlaveHandlerService.execute Command(Lorg/eclipse/core/commands/ParameterizedCommand;Lorg /eclipse/swt/widgets/Event;)Ljava/lang/Object;+6
j org.eclipse.ui.menus.CommandContributionItem.handleWidgetSel ection(Lorg/eclipse/swt/widgets/Event;)V+79
j org.eclipse.ui.menus.CommandContributionItem.access$19(Lorg/ eclipse/ui/menus/CommandContributionItem;Lorg/eclipse/swt/wi dgets/Event;)V+2
j org.eclipse.ui.menus.CommandContributionItem$5.handleEvent(L org/eclipse/swt/widgets/Event;)V+51
j org.eclipse.swt.widgets.Display.runDeferredEvents()Z+92
j org.eclipse.swt.widgets.Display.readAndDispatch()Z+43
j org.eclipse.ui.internal.Workbench.runEventLoop(Lorg/eclipse/ jface/window/Window$IExceptionHandler;Lorg/eclipse/swt/widge ts/Display;)V+9
j org.eclipse.ui.internal.Workbench.runUI()I+555
j org.eclipse.ui.internal.Workbench.access$4(Lorg/eclipse/ui/i nternal/Workbench;)I+1
j org.eclipse.ui.internal.Workbench$7.run()V+55
j org.eclipse.core.databinding.observable.Realm.runWithDefault (Lorg/eclipse/core/databinding/observable/Realm;Ljava/lang/R unnable;)V+12
j org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Lorg /eclipse/swt/widgets/Display;Lorg/eclipse/ui/application/Wor kbenchAdvisor;)I+18
j org.eclipse.ui.PlatformUI.createAndRunWorkbench(Lorg/eclipse /swt/widgets/Display;Lorg/eclipse/ui/application/WorkbenchAd visor;)I+2
j de.sim.phcl.test.application.Application.start(Lorg/eclipse/ equinox/app/IApplicationContext;)Ljava/lang/Object;+12
j org.eclipse.equinox.internal.app.EclipseAppHandle.run(Ljava/ lang/Object;)Ljava/lang/Object;+135
j org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(Ljava/lang/Object;)Ljava/lang/Object;+103
j org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(Ljava/lang/Object;)Ljava/lang/Object;+29
j org.eclipse.core.runtime.adaptor.EclipseStarter.run(Ljava/la ng/Object;)Ljava/lang/Object;+149
0x00007f4f905fc800 JavaThread "Worker-0"
0x00007f4f902f4000 JavaThread " - Idle Thread" daemon
0x00007f4f90307000 JavaThread " - Main Queue Handler" daemon
0x00007f4f902dd800 JavaThread "Bundle File Closer" daemon
0x00000000427d7000 JavaThread "Worker-JM"
0x0000000042f78000 JavaThread "Framework Event Dispatcher" daemon
0x00007f4f90373000 JavaThread "Start Level Event Dispatcher" daemon
0x00007f4f901d7000 JavaThread "State Data Manager" daemon
0x00007f4f9022a000 JavaThread "OSGi Console"
0x000000004215c000 JavaThread "Low Memory Detector" daemon
0x0000000042159800 JavaThread "CompilerThread1" daemon
0x0000000042157000 JavaThread "CompilerThread0" daemon
0x0000000042154800 JavaThread "Signal Dispatcher" daemon
0x0000000042135800 JavaThread "Finalizer" daemon
0x000000004212e000 JavaThread "Reference Handler" daemon
=>0x00000000420cc800 JavaThread "main"
Other Threads:
0x0000000042129800 VMThread
0x0000000042167000 WatcherThread [id=2421]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
PSYoungGen total 23616K, used 5464K [0x00007f4fbcaf0000, 0x00007f4fbf280000, 0x00007f4fc7590000)
eden space 18112K, 6% used [0x00007f4fbcaf0000,0x00007f4fbcc0e080,0x00007f4fbdca0000)
from space 5504K, 78% used [0x00007f4fbdca0000,0x00007f4fbe0d8030,0x00007f4fbe200000)
to space 5760K, 0% used [0x00007f4fbece0000,0x00007f4fbece0000,0x00007f4fbf280000)
PSOldGen total 27328K, used 6185K [0x00007f4fa7590000, 0x00007f4fa9040000, 0x00007f4fbcaf0000)
object space 27328K, 22% used [0x00007f4fa7590000,0x00007f4fa7b9a490,0x00007f4fa9040000)
PSPermGen total 35456K, used 35286K [0x00007f4f97590000, 0x00007f4f99830000, 0x00007f4fa7590000)
object space 35456K, 99% used [0x00007f4f97590000,0x00007f4f998058d8,0x00007f4f99830000)
[Updated on: Mon, 06 December 2010 03:32]
Re: Where to file a bug? - Ubuntu JVM Crash using Nebula widgets [message #643703 is a reply to message #643518] |
Tue, 07 December 2010 22:47 |
Eric Rizzo Messages: 3070 Registered: July 2009 |
https://bugs.eclipse.org/bugs/
The classification/project is Technology, the product is Nebula.
On 12/7/10 3:52 AM, Mark Hoffmann wrote:
> Hi all,
> crash.
> Mark
> SNIPPET:
> import org.eclipse.nebula.widgets.collapsiblebuttons.CollapsibleBut tons;
> import org.eclipse.swt.widgets.Display;
> public static void main(String[] args) {
> gl.marginWidth = 0;
> itemImage16);
> shell.open();
> display.sleep();
> display.dispose();
> LOG:
> linux-amd64 )
> # C
> Registers:
> C=native code)
> C
> t/widgets/Event;)V
> dgets/Event;)V+25
> idgets/Event;Z)V+73
> idgets/Event;)V+4
> dgets/Event;)V+2
> t/widgets/Event;)V
> dgets/Event;)V+25
> ts/Display;)V+9
> kbenchAdvisor;)I+18
> Other Threads:
> Heap
Current Time: Thu Apr 25 20:20:13 GMT 2024
Powered by FUDForum. Page generated in 0.08520 seconds
