Re: Xtext / Xpand problem [message #642784 is a reply to message #642706] |
Thu, 02 December 2010 16:48 |
Mehdi Missing name Messages: 22 Registered: December 2010 |
Junior Member |
I actualy managed to find a good solution using an Xtext grammar (a model to model transformation) but now i have another problem :
in my xtext model (domain specific model) i defined a number of parameters to be able to write this in the plugin editor :
501 = TEST_Unit ( 15000 );
now my problem is that i must add the quote " to String values like this or else i have several Errors in the plugin editor :
"501" = TEST_Unit ( " 15000 Bac tests " );
Any solution for this kind of problem ?
As for my DSL this is the part where i'm having this problem :
Application :
{Application}
(Instance_def=EString) "=" (Instance_value=EString) "(" (Instance_long=EString) ");" ;
EString:
STRING | ID;
Thank you for your time - Again -
[Updated on: Thu, 02 December 2010 16:49] Report message to a moderator
FUDForum. Page generated in 0.05639 seconds
