Home » Modeling » TMF (Xtext) » [Xtext] Serializing an expression DSL with parentheses and different operator priorities
[Xtext] Serializing an expression DSL with parentheses and different operator priorities [message #641997] Mon, 29 November 2010 13:44 Go to next message
Cédric Vidal is currently offline Cédric VidalFriend
--------------010801080105030909000700
Hi guys,
I'm facing a difficulty with Xtext. I'd like the following DSL to be
serializable (I'm running Xtext 1.0.0):
Expression : Addition;
Addition returns Expression :
Multiplication ({Operation.left=current} op=('+'|'-') right=Addition)?
Multiplication returns Expression :
Literal ({Operation.left=current} op=('*'|'/') right=Multiplication)?
Literal returns Expression:
'(' Expression ')'
| {IntLiteral} value=INT
The following model "(5 + 3) * 2" serializes as "5 + 3 * 2" which is not
valid as the parentheses are mandatory to preserve operator priority. It
could serialize either as "(5 + 3) * 2" or "((5 + 3) * 2)" in order to
be valid.
Usually for this kind of problem I use the IValueSerializer API but in
that case, parenthetis are not considered unassigned values.
So I'd like to know where to customize the serialization process in
order to add '(' and ')' keywords where appropriate.
Please find attached a sample project with unit tests.
C
Re: [Xtext] Serializing an expression DSL with parentheses and different operator priorities [message #642007 is a reply to message #641997] Mon, 29 November 2010 14:22 Go to previous messageGo to next message
Meinte Boersma is currently offline Meinte BoersmaFriend
If there's no need to go with the usual serializer, you could always use an "old-fashioned" Xpand template to serialize it in a way which makes sense, possibly combining it with some Xtend to "look ahead" to see whether higher-precedence binary operators following the current AST node require parentheses around the latter. (Or you just hack it together in even more old-fashioned Java Wink After all, the grammar isn't very big.)
Re: [Xtext] Serializing an expression DSL with parentheses and different operator priorities [message #642018 is a reply to message #642007] Mon, 29 November 2010 14:52 Go to previous messageGo to next message
Hi Meinte,
Actually, the sample expression DSL is just a snippet to illustrate my
case. It is part of a much larger DSL and I can't afford going the code
generation template way.
I really need to find a way to customize the serialization process to
handle that case.
> together in even more old-fashioned Java ;) After all, the grammar isn't
> very big.)
Re: [Xtext] Serializing an expression DSL with parentheses and different operator priorities [message #642023 is a reply to message #642018] Mon, 29 November 2010 15:24 Go to previous messageGo to next message
Actually, I just realized that in the sample, the parentheses are
actually correctly serialized.
It's in the bigger DSL that they are not. I have to figure out what is
the difference between the two that makes the serialization fail.
Le 29/11/2010 15:54, Cédric Vidal a écrit :
> Hi Meinte,
> handle that case.
>> very big.)
Re: [Xtext] Serializing an expression DSL with parentheses and different operator priorities [message #642029 is a reply to message #641997] Mon, 29 November 2010 15:35 Go to previous messageGo to next message
Sebastian Zarnekow is currently offline Sebastian ZarnekowFriend
Hi Cédric,
your expressions are right associative, so the serializer is completely
right:
should actually read
right=Multiplication/* <- !!*/)?
Sebastian
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
Am 29.11.10 14:44, schrieb Cédric Vidal:
Re: [Xtext] Serializing an expression DSL with parentheses and different operator priorities [message #642030 is a reply to message #642029] Mon, 29 November 2010 15:36 Go to previous messageGo to next message
That was to fast. The expression should read:
right=Multiplication/* <- !!*/) * /* <- !! */
Sebastian
Am 29.11.10 16:35, schrieb Sebastian Zarnekow:
> Hi Cédric,
> right:
> Sebastian
Re: [Xtext] Serializing an expression DSL with parentheses and different operator priorities [message #642081 is a reply to message #642030] Mon, 29 November 2010 18:08 Go to previous messageGo to next message
Hi Sebastian, thanx for the clarification, indeed, my grammar was
erroneous in respect to associativity. But sadly, the problem is
elsewhere. I've investigated and narrowed the issue.
The following grammar serializes correctly:
Multiplication ({Operation.left=current} op=OPERATOR_ADD
right=Multiplication) *
Literal ({Operation.left=current} op=OPERATOR_MUL right=Literal) *
'(' Expression ')'
terminal OPERATOR_MUL : '*'|'/';
terminal OPERATOR_ADD : '+'|'-';
When using rules instead of terminals, serialization fails to include
parentheses:
'(' Expression ')'
OPERATOR_MUL : '*'|'/'; // <-- using rules instead of terminals
--> parentheses are not serialized
When operators are specific meta classes which are referenced, it also
fails. The following DSL illustrates that. It adds the possibility to
define operators and reference them.
Evaluation:
(ops+=Operator ';') *
'exp' exp=Expression
Multiplication ({Operation.left=current} op=[Operator|OPERATOR_ADD]
Literal ({Operation.left=current} op=[Operator|OPERATOR_MUL]
right=Literal) *
'(' Expression ')'
Operator :
'op' name=(OPERATOR_ADD|OPERATOR_MUL)
--> fails with "org.eclipse.xtext.conversion.ValueConverterException:
The value '*' is an invalid OPERATOR_ADD"
Cédric
> Sebastian
Re: [Xtext] Serializing an expression DSL with parentheses and different operator priorities [message #642082 is a reply to message #642081] Mon, 29 November 2010 18:10 Go to previous messageGo to next message
Note that I'm using Xtext 1.0.0, it might work in Xtext 1.0.1
> '(' Expression ')'
> parentheses:
> '(' Expression ')'
> Evaluation:
> right=Literal) *
> '(' Expression ')'
> Operator :
> Cédric
>> Regards,
>> Sebastian
Re: [Xtext] Serializing an expression DSL with parentheses and different operator priorities [message #642084 is a reply to message #642081] Mon, 29 November 2010 18:23 Go to previous messageGo to next message
Hi Cedric,
would you please be so kind and file your reproducable sample as a
bugzilla? Thanks.
Sebastian
Am 29.11.10 19:08, schrieb Cédric Vidal:
> '(' Expression ')'
> parentheses:
> '(' Expression ')'
> Evaluation:
> right=Literal) *
> '(' Expression ')'
> Operator :
> Cédric
>> Regards,
>> Sebastian
Re: [Xtext] Serializing an expression DSL with parentheses and different operator priorities [message #642107 is a reply to message #642084] Mon, 29 November 2010 20:53 Go to previous message
Sure, here you go:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=331378
Le 29/11/2010 19:23, Sebastian Zarnekow a écrit :
> Hi Cedric,
> bugzilla? Thanks.
> Sebastian
Previous Topic:ImportedNamespaceAwareLocalScopeProvider
Next Topic:How to run MWE2 code generator programmatically in the eclipse IDE plugin
Current Time: Tue Apr 16 19:24:18 GMT 2024
Powered by FUDForum. Page generated in 0.09421 seconds
