Home » Eclipse Projects » Mylyn » Synchronization of fix version updated JIRA tasks
Synchronization of fix version updated JIRA tasks [message #64501] Tue, 20 January 2009 05:27 Go to next message
Hi :)
Before posting to the Mylyn team, I would like to know if the following
is a bug :) Here are the differents steps :
1- A JIRA task is updated on the JIRA server : precisely a new version is
added to the project and the fix version of the task is modified to be now
the newly added version. For example, there were 2 initial versions (2.2.3
and 2.5), version 2.4 is added and the fix version of TASK-XXX is moved
from 2.5 to 2.4 ;
2- On Mylyn/Eclipse, TASK-XXX is opened. Fix versions listbox (Attributes
section) contains 2.2.3 and 2.5 values. Then TASK-XXX is synchronized
(F5). The link "Task has incoming changes" appears ;
3- Clicking on the link does not modify Fix versions listbox which still
contains 2.2.3 and 2.5 values ;
4- Every time the Synchronize action is done, link "Task has incoming
changes" appears even if no modification on the JIRA has been done.
It looks like a bug but did someone face this before ?
Thanks in advance for your help and your advices
Eric
Re: Synchronization of fix version updated JIRA tasks [message #64524 is a reply to message #64501] Tue, 20 January 2009 05:40 Go to previous message
Eric TOURNIER wrote:
> Hi :)
> is added to the project and the fix version of the task is modified to
> be now the newly added version. For example, there were 2 initial
> versions (2.2.3 and 2.5), version 2.4 is added and the fix version of
> TASK-XXX is moved from 2.5 to 2.4 ;
> (Attributes section) contains 2.2.3 and 2.5 values. Then TASK-XXX is
> synchronized (F5). The link "Task has incoming changes" appears ;
> Eric
You can update the server values by going to the query definition window
and clicking the appropriate button (at least for trac and bugzilla).
Does it work then?
Perhaps a new feature for Mylyn could be that new server values are
retrieved automatically when it encounters an unknown value during
synchronization. Mylyn could also display a friendly dialog explaining
that it had encountered unknown value and asks if the values should be
updated from the repository. This dialog should contain a checkbox to
disable the dialog, because maybe some bad configured repository causes
tasks to be sent out with unknown properties that can never be retrieved.
Jorrit
Re: Synchronization of fix version updated JIRA tasks [message #595871 is a reply to message #64501] Tue, 20 January 2009 05:40 Go to previous message
> Hi :)
> Eric
Does it work then?
Jorrit
Previous Topic:Possible feature request
Next Topic:How to query only one bug from eclipse's bugzilla
Current Time: Tue Jul 22 15:28:06 EDT 2025
Powered by FUDForum. Page generated in 0.03703 seconds
