Home » Modeling » Epsilon » Inheritance
Inheritance [message #5764] Fri, 28 November 2008 09:19 Go to next message
Hia,
Is it possible to deal with multiple inheritance with ETL? I've been
reading the pdfs available but haven't yet found the answer... Any
pointers to relevant documentation would be great.
Edd.
Re: Inheritance [message #5781 is a reply to message #5764] Fri, 28 November 2008 09:37 Go to previous messageGo to next message
Hi Edd,
This is supported. You can write something like
rule A
transform a : A!A
to b : B!B
extends C, D, E {
Dimitrios
Edward Turner wrote:
> Hia,
> Edd.
Re: Inheritance [message #5798 is a reply to message #5781] Fri, 28 November 2008 09:43 Go to previous messageGo to next message
Great! Thanks,
Edd
Re: Inheritance [message #5814 is a reply to message #5781] Mon, 01 December 2008 10:42 Go to previous messageGo to next message
Also, I was wondering if the following could be confirmed? :
If A extends B, and B extends C and D, is it true that all instances of
A inherit from C and D (via B)? (Or perhaps is it possible to create a
particular instance of A whose ancestor chain is precisely <B,C> -- and
not <B,D>)?
Thanks in advance,
Edd
Re: Inheritance [message #5830 is a reply to message #5814] Mon, 01 December 2008 10:56 Go to previous message
Hi Edd,
> Also, I was wondering if the following could be confirmed? : If A
> extends B, and B extends C and D, is it true that all instances of A
That is correct.
> not <B,D>)?
You could do this indirectly by setting respective guards to C and D.
> Thanks in advance,
> Edd
Dimitrios
Re: Inheritance [message #562653 is a reply to message #5764] Fri, 28 November 2008 09:37 Go to previous message
Hi Edd,
rule A
transform a : A!A
to b : B!B
extends C, D, E {
Dimitrios
> Hia,
> Edd.
Re: Inheritance [message #562670 is a reply to message #5781] Fri, 28 November 2008 09:43 Go to previous message
Great! Thanks,
Edd
Re: Inheritance [message #562693 is a reply to message #5781] Mon, 01 December 2008 10:42 Go to previous message
not <B,D>)?
Thanks in advance,
Edd
Re: Inheritance [message #562713 is a reply to message #5814] Mon, 01 December 2008 10:56 Go to previous message
Hi Edd,
That is correct.
> not <B,D>)?
> Thanks in advance,
> Edd
Dimitrios
Previous Topic:Inheritance
Next Topic:ETL and UML Stereotypes
Current Time: Sat Jul 19 14:08:30 EDT 2025
Powered by FUDForum. Page generated in 0.04065 seconds
