Problems in UI tests [message #639172] |
Mon, 15 November 2010 14:08 |
I want to implement UITests to test hyperlinking functionality.
I initialized my enviroment with
Guice.createInjector(Modules2.mixin( new MaskRuntimeModule(),
new WorkflowRuntimeModule(),
new MaskUiModule(Activator.getInstance()),
new WorkflowUiModule(Activator.getInstance()),
new SharedStateModule()));
We implemented a builder, which starts a transformation from dsl to xml. This transformation throws the following error:
EvaluationException : Couldn't resolve type for 'workflowdef::WorkflowType'. Did you forget to configure the corresponding metamodel?
vsa::marvin::mod::workflow::xml::Workflow2XML.ext[4907,2956] on line 99 'workflowdef::WorkflowType fillWorkflowTypeAbstract(workflowdef::WorkflowType wftype,workflow::StatefulWorkflow abstractworkflow)'
If I add xml-runtime-module to the injector, there comes an error:
Caused by: org.eclipse.xtext.resource.ClasspathUriResolutionException: java.lang.IllegalStateException: Couldn't find resource on classpath. URI was 'classpath:/vsa/marvin/mod/workflow/XML.xmi&apo s;
at org.eclipse.xtext.resource.ClassloaderClasspathUriResolver.r esolve(ClassloaderClasspathUriResolver.java:48)
at org.eclipse.xtext.resource.XtextResourceSet.resolveClasspath URI(XtextResourceSet.java:35)
at org.eclipse.xtext.resource.XtextResourceSet.access$0(XtextRe sourceSet.java:34)
at org.eclipse.xtext.resource.XtextResourceSet$1.normalize(Xtex tResourceSet.java:53)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:361)
at org.eclipse.xtext.resource.SynchronizedXtextResourceSet.getR esource(SynchronizedXtextResourceSet.java:23)
at org.eclipse.xtext.parser.BaseEPackageAccess.loadResource(Bas eEPackageAccess.java:52)
Caused by: java.lang.IllegalStateException: Couldn't find resource on classpath. URI was 'classpath:/vsa/marvin/mod/workflow/XML.xmi&apo s;
at org.eclipse.xtext.resource.ClassloaderClasspathUriResolver.f indResourceOnClasspath(ClassloaderClasspathUriResolver.java: 60)
at org.eclipse.xtext.resource.ClassloaderClasspathUriResolver.r esolve(ClassloaderClasspathUriResolver.java:45)
4 errors
at com.google.inject.internal.Error,
but I don't have my grammar of xml-model not stored in any xmi - file.
Can you give me a hint how to solve this problem?
Best regards
Markus
[Updated on: Mon, 15 November 2010 14:08] Report message to a moderator
Re: Problems in UI tests [message #639351 is a reply to message #639172] |
Tue, 16 November 2010 08:41 |
Hi again,
found the solution....
I deactivated automatic build for this project and build the project by calling the api.
Now it works... maybe project was not completely injected before ?
Best regards
Markus
FUDForum. Page generated in 0.02993 seconds
