Re: Newbie Question [message #638352 is a reply to message #638350] |
Wed, 10 November 2010 23:33 |
On 2010.11.10 16:07, Brian wrote:
> I am new to Java again (picked it up a few years ago, never went very
> far with it), and I am running through some online tutorials, one of
> which references a source code they wrote called TextIO, and the file is
> given, which I downloaded. In windows I was able to drag and drop the
> file into my project, and all worked well. My questions is this: Is
> there a place to put this TextIO.java file so that it is automatically
> added to all new java projects, or is there a setting in Eclipse where I
> may specify a folder to search for such files to automatically be added?
> Also, what online tutorials/resources have you found to be beneficial
> for learning Java as a newbie?
> Thanks in advance
(Not sure why you'd want to add a Java file to each and every project. I
don't know of a way to do that, but I don't know everything.)
For learning Java I recommend the following resources:
1) A "method"--a fun learning book like Head First Java.
2) A "grammar" --a book containing a more formal description of the
language than the method will provide like Bruce Eckel's Thinking in
Java; you'll use this book to look stuff up; or, you can just use Google.
3) A good forum --Java Ranch is probably the very best and it's a
"kinder-gentler" place; also good are stackOverflow and jguru.
4) A development environment --you can't do better than Eclipse;
NetBeans is good too, but if you decide to write Java professionally,
it's Eclipse all the way almost no matter where you work.
4bis) Don't forget to use Eclipse forums--a great place for help with
Eclipse, but it's not so much the place to ask purely Java questions.
5) Good tutorials --for advanced, practical things that go with #4:
these rather go with the development environment since they relate it
and any frameworks you use; you can't beat http://www.vogella.de
Re: Newbie Question [message #638578 is a reply to message #638352] |
Thu, 11 November 2010 16:23 |
David Kerber Messages: 100 Registered: July 2009 |
In article <ibf9tj$luk$1@news.eclipse.org>, russ@windofkeltia.com
says...
> > Thanks in advance
That would essentially be a user library. I don't believe you can
automatically include it in every project, but just put it in some
central location and import it when you start a new project.
D
FUDForum. Page generated in 0.08434 seconds
