I have a problem when starting Glassfish with the WTP Server Plugin from my Eclipse IDE
After an JDK Update to Version 1.6.0_22 I can no longer start the server. I got a nullPointer Exception (!?)
An internal error occurred during: "Starting GlassFish v3 Java EE 6 at localhost".
When I try to reconfigure the Runtime Environment for my Glassfish and I try to set the current JDK I got an "Unhandled event loop exception":
at com.sun.enterprise.jst.server.sunappsrv.InstallableServerTypeDefinitionRuntimeDecorator.getValues(InstallableServerTypeDefinitionRuntimeDecorator.java:225)
at org.eclipse.jst.server.generic.ui.internal.ServerTypeDefinitionRuntimeDecorator.validate(ServerTypeDefinitionRuntimeDecorator.java:34)
at com.sun.enterprise.jst.server.sunappsrv.InstallableRuntimeServerRuntimeWizardFragment.exit(InstallableRuntimeServerRuntimeWizardFragment.java:131)
at org.eclipse.wst.server.ui.internal.wizard.TaskWizard.performFinish(TaskWizard.java:161)
at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDialog.java:752)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:373)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:624)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:228)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1176)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3493)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3112)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
at org.eclipse.jface.window.Window.open(Window.java:801)
at org.eclipse.wst.server.ui.internal.editor.OverviewEditorPart.showWizard(OverviewEditorPart.java:844)
at org.eclipse.wst.server.ui.internal.editor.OverviewEditorPart.editRuntime(OverviewEditorPart.java:816)
at org.eclipse.wst.server.ui.internal.editor.OverviewEditorPart$5.linkActivated(OverviewEditorPart.java:402)
at org.eclipse.ui.forms.widgets.AbstractHyperlink.handleActivate(AbstractHyperlink.java:233)
at org.eclipse.ui.forms.widgets.AbstractHyperlink.handleMouseUp(AbstractHyperlink.java:327)
at org.eclipse.ui.forms.widgets.AbstractHyperlink.access$2(AbstractHyperlink.java:311)
at org.eclipse.ui.forms.widgets.AbstractHyperlink$4.handleEvent(AbstractHyperlink.java:125)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2221)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:493)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:113)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:194)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:559)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
eclipse.buildId=
java.version=1.6.0_22
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=de_DE
Framework arguments: -product org.eclipse.epp.package.jee.product -product org.eclipse.epp.package.jee.product -product org.eclipse.epp.package.jee.product
Command-line arguments: -os linux -ws gtk -arch x86 -product org.eclipse.epp.package.jee.product -product org.eclipse.epp.package.jee.product -data /home/rsoika/eclipse/imixs-office -product org.eclipse.epp.package.jee.product
If I start Eclipse with a new empty Workspace I can configure a new Glassfish Server with no problems.
Did anybody have had such a problem - and maybe any solution
I am using
Linux Ubuntu 10.04
Eclipse Galileo Build 20100218-1602
Glassfish V 3.0.1
Thanks for any help
Ralph
