Referenced Library cannot be read in Java Class [message #630551] |
Mon, 04 October 2010 05:32 |
Hans Kristanto Messages: 1 Registered: October 2010 |
Junior Member |
Hi All,
I'm newbie in Eclipse. Currently i'm using Eclipse Helios and try to learn building Spring from scratch. I created lib folder in WEB-INF and i added all spring library and dependencies. After that, i try to add build path and refere to class folder to lib. I tried to build using ANT and everything is working fine. A 'Referenced Library' node appeared in the project structure. But my question, why java class cannot read all spring packages in Referenced Library? My code are full of error signs but actually, i can run the project in web server. Is it possible to make java class can read referenced library?
Really looking forward to hearing from you all.
FUDForum. Page generated in 0.03172 seconds
