full path for 'runtimeProject' property in the workflow file [message #629737] |
Wed, 29 September 2010 12:32 |
Cong Kinh NGUYEN Messages: 47 Registered: February 2010 |
Member |
Hi everybody,
Have you ever used the example-maven in the blog http://kthoms.wordpress.com/2009/07/20/building-tmf-xtext-pr ojects-with-maven/ ?
In this example, I cannot give the full path to the GenerateMyDsl.mwe for the property as the following:
<property name="runtimeProject" value="../${projectName}"/>
to (for example):
<property name="runtimeProject" value="/home/kinh/test/${projectName}"/>
Because in our situation, we want to use Maven with xtext and many other modules with many levels of directory. So to compile the code on top of the all modules, it must provide the full path (for example ${basedir}). Unfortunately, when I tried to do so, it didn't work. Could you know ho to solve it?
Thanks in advance,
Kinh
FUDForum. Page generated in 0.02892 seconds
