Can't find source for specific jar/class when debugging tomcat webapp [message #626934] |
Wed, 22 September 2010 19:05 |
Dave N Messages: 1 Registered: September 2010 |
Junior Member |
Hi all,
I'm fairly new to java/eclipse development and I'm having a bit of a problem debugging code from a specific jar in a web app that my company uses.
First off, I have Tomcat setup properly and can run the webapp successfully (other than the bug that I'm trying to find!). There are about two dozen jar files in the lib directory for the webapp, and when I've tried to debug files in other jars the debugger catches their breakpoints correctly and everything is happy. Breakpoints I set in code in the new jar are skipped, and when I catch a breakpoint further along the debug stack any attempt to click to the class I'm interested in results in "Source not found".
I click the "Edit Source Lookup Path..." button, click the project that contains the code, and it returns me to the "Source not found" error. I've tried setting up the lookup path both as a project as well as a File System Directory and a Workspace Project. Same result every time. A weird thing I've noticed is it appears to blink the source file up for a fraction of a second before telling me it can't find the source.
I'm a little fuzzy on how exactly the debugger ties a particular function call in the debug stack window to source code - is it simply based on the package and class name of the course file? If so, I can't see why it wouldn't be working.
Any ideas? Thanks in advance
FUDForum. Page generated in 0.02981 seconds
