Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [CDO] Client registration timeout exception
| [CDO] Client registration timeout exception [message #616266] |
Mon, 14 April 2008 00:07 |
I'm new to CDO and I'm trying to connect to a CDO server using the "CDO
Sessions View" (org.eclipse.emf.cdo.CDOSession.CDOSessionsView). Here is
rundown of what I'm doing:
- JVM 1.5.0 (using OS X) , Eclipse 3.4m5,
- I run a CDO server using the product configuration
org.eclipse.emf.cdo.server.product.
- I run an eclipse workbench configuration with the following additional
plugins:
org.eclipse.emf.cdo (0.8.0)
org.eclipse.emf.cdo.edit (0.8.0)
org.eclipse.emf.cdo.protocol (0.8.0)
org.eclipse.emf.cdo.ui (0.8.0)
org.eclipse.emf.net4j (0.8.0)
org.eclipse.emf.net4j.db (0.8.0)
org.eclipse.emf.net4j.db.derby (0.8.0)
org.eclipse.emf.net4j.tcp (0.8.0)
org.eclipse.emf.net4j.util (0.8.0)
org.eclipse.emf.net4j.util.ui (0.8.0)
(and other emf 2.4 plugins)
- In the CDO sessions view, I try to open a session using the dialog.
(Server - tcp://localhost:2036, Repository Name - repo, Legacy Support
checkbox is disabled and not checked)
- After a wait a dialog box comes up with "Unable to open a session on the
specified repository tcp://localhost:2036/repo?disableLegacyObjects=true"
- A registration error is occuring in the client
(org.eclipse.net4j.internal.tcp.ControlChannel # registerChannel):
[ERROR] Registration timeout after 10000 milliseconds
org.eclipse.net4j.util.concurrent.TimeoutRuntimeException: Registration
- I've extended (and also disabled) the CDO timeout values but this hasn't
resulted in a registration.
- The client and server traces and cdo-server.xml are included below. If
needed I can access the ClientTCPConnector using the Introspector view to
retrieve any required information.
Any help would be appreciated.
=========================== cdo-server.xml ====================
<cdoServer>
<acceptor type="tcp" listenAddr="0.0.0.0" port="2036">
<negotiator type="challenge" description="/temp/users.db"/>
</acceptor>
<repository name="repo">
<property name="overrideUUID"
value="1ff5d226-b1f0-40fb-aba2-0c31b38c764f"/>
<property name="supportingAudits" value="true"/>
<property name="verifyingRevisions" value="false"/>
<property name="rememberingKnownTypes" value="false"/>
<property name="currentLRUCapacity" value="10000"/>
<property name="revisedLRUCapacity" value="100"/>
<store type="db">
<!-- type: horizontal | vertical | <any user-contributed type>-->
<mappingStrategy type="horizontal">
<!-- ONE_TABLE_PER_REFERENCE | ONE_TABLE_PER_CLASS |
ONE_TABLE_PER_PACKAGE | ONE_TABLE_PER_REPOSITORY | LIKE_ATTRIBUTES -->
<property name="toManyReferences"
value="ONE_TABLE_PER_REFERENCE"/>
<!-- LIKE_ATTRIBUTES | LIKE_TO_MANY_REFERENCES-->
<property name="toOneReferences" value="LIKE_ATTRIBUTES"/>
<!-- MODEL | STRATEGY-->
<property name="mappingPrecedence" value="MODEL"/>
</mappingStrategy>
<dbAdapter name="derby"/>
<dataSource class="org.apache.derby.jdbc.EmbeddedDataSource"
databaseName="/cdodb"
createDatabase="create"/>
<!-- <dbAdapter name="derby"/>
<dataSource class="org.apache.derby.jdbc.ClientDataSource"
databaseName="cdodb"
createDatabase="create"/>-->
<!--<dbAdapter name="hsqldb"/>
<dataSource class="org.eclipse.net4j.db.hsqldb.HSQLDBDataSource"
database="jdbc:hsqldb:mem:cdodb1"
user="sa"/>-->
<!--<dbAdapter name="mysql"/>
<dataSource class="com.mysql.jdbc.jdbc2.optional.MysqlDataSource"
url="jdbc:mysql://localhost/cdodb1"
user="sa"/>-->
</store>
</repository>
</cdoServer>
=========================== Server Trace ========================
Configuration location:
file:workspace/.metadata/.plugins/org.eclipse.pde.core/CDO Server
Reduced/
Configuration file:
Reduced/config.ini loaded
Install location:
file:/Applications/eclipse 3.4/eclipse/
Framework located:
3.4/eclipse/plugins/org.eclipse.osgi_3.4.0.v20080205.jar
Framework classpath:
Splash location:
null
Debug options:
Reduced/.options loaded
osgi> Time to load bundles: 483
Starting application: 3526
Thread-0 [debug.om] Starting bundle org.eclipse.net4j.util
Thread-0 [debug.lifecycle] Activating ManagedContainer
Thread-0 [debug.lifecycle] Activating {}
Thread-0 [debug.lifecycle.dump] DUMP PluginFactoryRegistry@1
Registry.autoCommit = true
Registry.transaction = null
HashMapRegistry.map =
org.eclipse.net4j.connectors[tcp]=Factory[org.eclipse.net4j. connectors,
tcp]
org.eclipse.net4j.randomizers[default]=Factory[org.eclipse.n et4j.randomizers,
default]
org.eclipse.net4j.userManagers[file]=Factory[org.eclipse.net 4j.userManagers,
file]
org.eclipse.net4j.Negotiators[challenge]=Factory[org.eclipse .net4j.Negotiators,
challenge]
org.eclipse.net4j.selectors[tcp]=Factory[org.eclipse.net4j.s electors,
tcp]
org.eclipse.net4j.bufferProviders[default]=Factory[org.eclip se.net4j.bufferProviders,
default]
org.eclipse.net4j.acceptors[tcp]=Factory[org.eclipse.net4j.a cceptors,
tcp]
org.eclipse.net4j.executorServices[default]=Factory[org.ecli pse.net4j.executorServices,
default]
org.eclipse.net4j.serverProtocols[cdo]=Factory[org.eclipse.n et4j.serverProtocols,
cdo]
extensionRegistryListener =
org.eclipse.net4j.internal.util.factory.PluginFactoryRegistr y$1@12ce69
Thread-0 [debug.lifecycle] Activating []
Thread-0 [debug.om] Starting bundle org.eclipse.net4j.tcp
Thread-0 [debug.lifecycle.dump] DUMP PluginElementProcessorList@2
processors =
org.eclipse.net4j.internal.util.security.ChallengeNegotiator Configurer @31ac05
org.eclipse.internal.net4j.Net4jTransportInjector@1492ed
org.eclipse.net4j.internal.tcp.TCPSelectorInjector@ba3f9a
org.eclipse.net4j.internal.util.container.PluginElementProce ssorList$1@594680
Thread-0 [debug.lifecycle.dump] DUMP PluginContainer@3
ManagedContainer.factoryRegistry =
tcp]
default]
file]
challenge]
tcp]
default]
tcp]
default]
cdo]
ManagedContainer.postProcessors =
ManagedContainer.elementRegistry =
ManagedContainer.maxElementID = 0
ManagedContainer.elementListener =
org.eclipse.net4j.internal.util.container.ManagedContainer$1@d6c8b9
Thread-0 [debug.om] Plugin container created: ManagedContainer
Thread-0 [debug.om] Starting bundle org.eclipse.emf.cdo.server
Thread-0 [debug.om] Starting application org.eclipse.emf.cdo.server.app
[INFO] CDO Server starting
Thread-0 [debug.repository] Configuring CDO server from workspace/CDO
Server/server/config/cdo-server.xml
Thread-0 [debug.repository] Configuring repository repo (type=default)
Thread-0 [debug.om] Starting bundle org.eclipse.emf.cdo.protocol
Thread-0 [debug.model] Created
CDOPackage(URI=http://www.eclipse.org/emf/CDO/core/1.0.0, name=cdocore,
dynamic=false, metaIDRange=null)
Thread-0 [debug.model] Created CDOClass(ID=0, name=CDOObject)
Thread-0 [debug.model] Adding class: CDOClass(ID=0, name=CDOObject)
Thread-0 [debug.model] Added package:
CDOPackage(URI=http://www.eclipse.org/emf/CDO/resource/1.0.0,
name=cdoresource, dynamic=false, metaIDRange=null)
Thread-0 [debug.model] Created CDOClass(ID=0, name=CDOResource)
Thread-0 [debug.model] Created CDOFeature(ID=9, name=path, type=STRING,
referenceType=null)
Thread-0 [debug.model] Adding feature: CDOFeature(ID=9, name=path,
type=STRING, referenceType=null)
Thread-0 [debug.model] Created CDOFeature(ID=2, name=contents,
type=OBJECT, referenceType=CDOClass(ID=0, name=CDOObject))
Thread-0 [debug.model] Adding feature: CDOFeature(ID=2, name=contents,
Thread-0 [debug.model] Adding class: CDOClass(ID=0, name=CDOResource)
Thread-0 [debug.om] Starting bundle org.eclipse.emf.cdo.server.db
Thread-0 [debug.om] Starting bundle org.eclipse.net4j.db
Thread-0 [debug.lifecycle] Activating Repository[repo, null]
Thread-0 [debug.lifecycle] Activating DBStore@4
Thread-0 [debug.sql] CREATE TABLE cdo_classes (id INTEGER, package
INTEGER, classifier INTEGER, name VARCHAR(255), abstract SMALLINT)
Thread-0 [debug.sql] -- Table/View 'CDO_CLASSES' already exists in Schema
'APP'.
Thread-0 [debug.sql] CREATE TABLE cdo_supertypes (type_id INTEGER,
supertype_package VARCHAR(255), supertype_classifier INTEGER)
Thread-0 [debug.sql] -- Table/View 'CDO_SUPERTYPES' already exists in
Schema 'APP'.
Thread-0 [debug.sql] CREATE TABLE cdo_features (id INTEGER, class INTEGER,
feature INTEGER, name VARCHAR(255), type INTEGER, reference_package
VARCHAR(255), reference_classifier INTEGER, many SMALLINT, containment
SMALLINT, idx INTEGER)
Thread-0 [debug.sql] -- Table/View 'CDO_FEATURES' already exists in Schema
'APP'.
Thread-0 [debug.sql] CREATE TABLE cdo_repository (name VARCHAR(255), uuid
VARCHAR(64), starts BIGINT, started BIGINT, stopped BIGINT, next_cdoid
BIGINT, next_metaid BIGINT)
Thread-0 [debug.sql] -- Table/View 'CDO_REPOSITORY' already exists in
Schema 'APP'.
Thread-0 [debug.sql] CREATE TABLE cdo_packages (id INTEGER, uri
VARCHAR(255), name VARCHAR(255), ecore CLOB, dynamic SMALLINT, range_lb
BIGINT, range_ub BIGINT)
Thread-0 [debug.sql] -- Table/View 'CDO_PACKAGES' already exists in Schema
'APP'.
Thread-0 [debug.sql] SELECT MAX(next_cdoid) FROM cdo_repository
Thread-0 [debug.sql] SELECT MAX(next_metaid) FROM cdo_repository
Thread-0 [debug.sql] UPDATE cdo_repository SET starts=starts+1,
started=1208142625647, stopped=0, next_cdoid=-1, next_metaid=-1
Thread-0 [debug.sql] SELECT MAX(id) FROM cdo_packages
Thread-0 [debug.sql] SELECT MAX(id) FROM cdo_classes
Thread-0 [debug.sql] SELECT MAX(id) FROM cdo_features
Thread-0 [debug.lifecycle] Activating horizontal
Thread-0 [debug.lifecycle] Activating ObjectTypeCache@5
Thread-0 [debug.lifecycle.dump] DUMP ObjectTypeCache@5
mappingStrategy = horizontal
table = null
idField = null
typeField = null
initializeLock = java.lang.Object@70f15e
Thread-0 [debug.lifecycle.dump] DUMP HorizontalMappingStrategy@6
MappingStrategy.store = DBStore@4
MappingStrategy.properties =
toOneReferences=LIKE_ATTRIBUTES
toManyReferences=ONE_TABLE_PER_REFERENCE
mappingPrecedence=MODEL
MappingStrategy.referenceTables =
MappingStrategy.classRefs =
MappingStrategy.resourceClassMapping = null
MappingStrategy.resourcePathMapping = null
MappingStrategy.resourceTable = null
MappingStrategy.resourceIDField = null
MappingStrategy.resourcePathField = null
objectTypeCache = ObjectTypeCache@5
Thread-0 [debug.lifecycle.dump] DUMP DBStore@4
Store.type = db
Store.properties = null
Store.repository = Repository[repo, null]
LongIDStore.lastObjectID = 2
dbSchema = null
dbAdapter = derby-10.2.2.0
dbConnectionProvider = org.apache.derby.jdbc.EmbeddedDataSource@a91761
nextPackageID = 1
nextClassID = 1
nextFeatureID = 1
Thread-0 [debug.lifecycle] Activating PackageManager@7
Thread-0 [debug.sql] SELECT uri, dynamic, range_lb, range_ub FROM
cdo_packages
Thread-0 [debug.lifecycle.dump] DUMP PackageManager@7
CDOPackageManagerImpl.packages =
http://www.eclipse.org/emf/CDO/core/1.0.0=CDOPackage(URI=http://www.eclipse.org/emf/CDO/core/1.0.0,
name=cdocore, dynamic=false, metaIDRange=null)
http://www.eclipse.org/emf/CDO/resource/1.0.0=CDOPackage(URI=http://www.eclipse.org/emf/CDO/resource/1.0.0,
CDOPackageManagerImpl.cdoCorePackage =
CDOPackageManagerImpl.cdoResourcePackage =
Thread-0 [debug.lifecycle] Activating SessionManager@8
Thread-0 [debug.lifecycle.dump] DUMP SessionManager@8
sessions =
lastSessionID = 0
Thread-0 [debug.lifecycle] Activating ResourceManager@9
Thread-0 [debug.lifecycle.dump] DUMP ResourceManager@9
idToPathMap =
pathToIDMap =
Thread-0 [debug.lifecycle] Activating RevisionManager@10
Thread-0 [debug.lifecycle.dump] DUMP RevisionManager@10
CDORevisionResolverImpl.revisions =
CDORevisionResolverImpl.currentLRUCapacity = 10000
CDORevisionResolverImpl.revisedLRUCapacity = 100
CDORevisionResolverImpl.currentLRU = LRU[size=0, capacity=10,000]
CDORevisionResolverImpl.revisedLRU = LRU[size=0, capacity=100]
cdoPathFeature = CDOFeature(ID=9, name=path, type=STRING,
referenceType=null)
Thread-0 [debug.lifecycle.dump] DUMP Repository@11
name = repo
store = DBStore@4
uuid = null
properties =
revisedLRUCapacity=100
rememberingKnownTypes=false
supportingAudits=true
verifyingRevisions=false
overrideUUID=1ff5d226-b1f0-40fb-aba2-0c31b38c764f
currentLRUCapacity=10000
supportingRevisionDeltas = null
supportingAudits = true
verifyingRevisions = null
packageManager = PackageManager@7
sessionManager = SessionManager@8
resourceManager = ResourceManager@9
revisionManager = RevisionManager@10
elements = [Lorg.eclipse.emf.cdo.server.IRepositoryElement;@10609a
lastMetaID = 0
Thread-0 [debug] Configuring Net4j server from workspace/CDO
Thread-0 [debug.lifecycle] Activating BufferPool[4,096]
BufferPoolMonitor [debug.buffer] Start monitoring
Thread-0 [debug.lifecycle.dump] DUMP BufferPool@12
BufferProvider.bufferCapacity = 4096
BufferProvider.providedBuffers = 0
BufferProvider.retainedBuffers = 0
provider = BufferFactory[4,096]
pooledBuffers = 0
Thread-0 [debug.lifecycle] Activating TCPSelector
Thread-0 [debug.lifecycle.dump] DUMP TCPSelector@13
selector = sun.nio.ch.KQueueSelectorImpl@c20307
clientOperations =
serverOperations =
thread = Thread[TCPSelector,5,main]
running = true
Thread-0 [debug.lifecycle] Activating TCPAcceptor[0.0.0.0:2,036]
Thread-0 [debug] Ordering server operation REGISTER
sun.nio.ch.ServerSocketChannelImpl[unbound]
TCPSelector [debug] Executing server operation REGISTER
TCPSelector [debug] Registering sun.nio.ch.ServerSocketChannelImpl[unbound]
Thread-0 [debug.lifecycle.dump] DUMP TCPAcceptor@14
Acceptor.negotiator = null
Acceptor.bufferProvider = BufferPool[4,096]
Acceptor.protocolFactoryRegistry =
tcp]
default]
file]
challenge]
tcp]
default]
tcp]
default]
cdo]
Acceptor.protocolPostProcessors =
Acceptor.receiveExecutor = java.util.concurrent.ThreadPoolExecutor@c6482
Acceptor.lifecycleEventConverter =
org.eclipse.internal.net4j.acceptor.Acceptor$1@9ab21d
Acceptor.acceptedConnectors =
selector = TCPSelector
selectionKey = sun.nio.ch.SelectionKeyImpl@85a317
startSynchronously = true
synchronousStartTimeout = 4000
startLatch = java.util.concurrent.CountDownLatch@af3479[Count = 0]
serverSocketChannel = sun.nio.ch.ServerSocketChannelImpl[/0.0.0.0:2036]
address = 0.0.0.0
port = 2036
[INFO] CDO Server started
Application Started: 14098
=========================== Client Trace ========================
file:workspace/.metadata/.plugins/org.eclipse.pde.core/CDO Client
Workspace/
Configuration file:
Workspace/config.ini loaded
Install location:
Framework located:
Debug options:
Workspace/.options loaded
osgi> Time to load bundles: 25
Starting application: 2843
Application Started: 13665
[INFO] Legacy system not available
Worker-4 [debug.model] Created
Worker-4 [debug.model] Created CDOClass(ID=0, name=CDOObject)
Worker-4 [debug.model] Adding class: CDOClass(ID=0, name=CDOObject)
Worker-4 [debug.model] Added package:
Worker-4 [debug.model] Created CDOClass(ID=0, name=CDOResource)
Worker-4 [debug.model] Created CDOFeature(ID=9, name=path, type=STRING,
referenceType=null)
Worker-4 [debug.model] Adding feature: CDOFeature(ID=9, name=path,
Worker-4 [debug.model] Created CDOFeature(ID=2, name=contents,
Worker-4 [debug.model] Adding feature: CDOFeature(ID=2, name=contents,
Worker-4 [debug.model] Adding class: CDOClass(ID=0, name=CDOResource)
Worker-4 [debug.model] Setting client info:
dynamic=false, metaIDRange=null) -->
org.eclipse.emf.ecore.impl.EcorePackageImpl@c76d78 (name: ecore) (nsURI:
http://www.eclipse.org/emf/2002/Ecore, nsPrefix: ecore)
Worker-4 [debug.model] Setting client info: CDOClass(ID=0, name=CDOObject)
--> org.eclipse.emf.ecore.impl.EClassImpl@e3afa9 (name: EObject)
(instanceClassName: null) (abstract: false, interface: false)
name=cdoresource, dynamic=false, metaIDRange=null) -->
org.eclipse.emf.cdo.eresource.impl.EresourcePackageImpl@bc80d8 (name:
eresource) (nsURI: http://www.eclipse.org/emf/CDO/resource/1.0.0,
nsPrefix: eresource)
name=CDOResource) --> org.eclipse.emf.ecore.impl.EClassImpl@1033db (name:
CDOResource) (instanceClassName: null) (abstract: false, interface: false)
Worker-4 [debug.model] Setting client info: CDOFeature(ID=2,
name=contents, type=OBJECT, referenceType=CDOClass(ID=0, name=CDOObject))
--> org.eclipse.emf.ecore.impl.EReferenceImpl@ad3677 (name: contents)
(ordered: true, unique: true, lowerBound: 0, upperBound: -1) (changeable:
true, volatile: false, transient: false, defaultValueLiteral: null,
unsettable: false, derived: false) (containment: true, resolveProxies:
false)
Worker-4 [debug.model] Setting client info: CDOFeature(ID=9, name=path,
type=STRING, referenceType=null) -->
org.eclipse.emf.ecore.impl.EAttributeImpl@d2eead (name: path) (ordered:
true, unique: true, lowerBound: 0, upperBound: 1) (changeable: true,
volatile: false, transient: false, defaultValueLiteral: null, unsettable:
false, derived: false) (iD: false)
Worker-4 [debug.connector] Setting userID null for
ClientTCPConnector[null:0]
BufferPoolMonitor [debug.buffer] Stop monitoring
Worker-4 [debug.connector] Setting state CONNECTING (was disconnected) for
ClientTCPConnector[localhost:2,036]
Worker-4 [debug] Ordering client operation REGISTER
java.nio.channels.SocketChannel[unconnected]
TCPSelector [debug] Executing client operation REGISTER
TCPSelector [debug] Connecting
java.nio.channels.SocketChannel[connection-pending
remote=localhost/127.0.0.1:2036]
TCPSelector [debug] Ordering client operation INTEREST CONNECT
java.nio.channels.SocketChannel[connected local=/127.0.0.1:51054
remote=localhost/127.0.0.1:2036] = false
TCPSelector [debug] Ordering client operation INTEREST READ
remote=localhost/127.0.0.1:2036] = true
TCPSelector [debug.connector] Setting state CONNECTED (was connecting) for
TCPSelector [debug] Executing client operation INTEREST CONNECT
TCPSelector [debug] Setting interest (was connect)
TCPSelector [debug] Executing client operation INTEREST READ
TCPSelector [debug] Setting interest READ
Worker-4 [debug.connector] Waiting for connection...
Worker-4 [debug.connector] Opening channel 0 with protocol cdo
Worker-4 [debug] Registering channel 0 with protocol SignalProtocol[cdo]
Worker-4 [debug.buffer] Created Buffer@1
Worker-4 [debug.buffer] Obtained Buffer@1
Worker-4 [debug.channel] Handling buffer from client: Buffer@1 -->
Channel[Control]
Worker-4 [debug] Ordering client operation INTEREST WRITE
TCPSelector [debug] Executing client operation INTEREST WRITE
TCPSelector [debug] Setting interest READ|WRITE (was read)
TCPSelector [debug] Writing java.nio.channels.SocketChannel[connected
local=/127.0.0.1:51054 remote=localhost/127.0.0.1:2036]
TCPSelector [debug.buffer] Writing 12 bytes
02 00 00 00 01 00 00 00 03 63 64 6f
TCPSelector [debug.buffer] Retaining Buffer@1
TCPSelector [debug] Ordering client operation INTEREST WRITE
TCPSelector [debug] Setting interest READ (was read|write)
org.eclipse.net4j.internal.tcp.ControlChannel.registerChanne l(ControlChannel.java:89)
org.eclipse.net4j.internal.tcp.TCPConnector.registerChannelW ithPeer(TCPConnector.java:269)
org.eclipse.internal.net4j.connector.Connector.openChannel(C onnector.java:401)
org.eclipse.internal.net4j.connector.Connector.openChannel(C onnector.java:388)
org.eclipse.emf.internal.cdo.CDOSessionImpl.doActivate(CDOSe ssionImpl.java:623)
org.eclipse.net4j.internal.util.lifecycle.Lifecycle.activate (Lifecycle.java:57)
org.eclipse.net4j.util.lifecycle.LifecycleUtil.activate(Life cycleUtil.java:71)
org.eclipse.net4j.util.lifecycle.LifecycleUtil.activate(Life cycleUtil.java:61)
org.eclipse.net4j.internal.util.container.ManagedContainer.g etElement(ManagedContainer.java:260)
org.eclipse.emf.cdo.internal.ui.actions.OpenSessionAction.do Run(OpenSessionAction.java:70)
org.eclipse.net4j.util.ui.actions.LongRunningAction$1.run(Lo ngRunningAction.java:164)
org.eclipse.net4j.util.om.monitor.MonitoredJob.run(Monitored Job.java:48)
Current Time: Sun Nov 09 06:00:23 EST 2025
Powered by FUDForum. Page generated in 0.03370 seconds
