Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » EMF Compare with model fragments
EMF Compare with model fragments [message #616192] Fri, 11 April 2008 01:10
Renata Roginsky is currently offline Renata RoginskyFriend
I'm having a problem trying to compare models that have fragments.
MatchService doesn't match the elements in the fragments.
To illustrate the problem I created a very simple model (3 classes) and
extracted one class into a fragment (an *.efx file). Then I created exact
copies of the model file and the fragment file.
When I compare these two models, MatchService is not able to match the
single class that is in the fragment.
DiffModel "reports" a model element (the class in the fragment) added to
one model and removed from the other model.
There are other diffs (a lot), but I don't even understand what they mean.
I have a small project with these models and a test class that does the
comparison, but it doesn't look like I can send an attachment via this
forum.
Let me know if you'd like me to send it and how I can do it.
We are using an older version of EMF compare (0.7) due to older version of
RSM we are stuck with at the moment, but there is a chance we'll be able
to upgrade soon.
Previous Topic:[Compare] Problem with getting RemoteRemoveModelElement vs. RemoteAddModelElement with 3 way compare
Next Topic:EMF Compare with model fragments
Current Time: Mon Jun 27 09:02:42 GMT 2022
Powered by FUDForum. Page generated in 0.01374 seconds
