Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Hibernate Mapping File not found
Hibernate Mapping File not found [message #615568] Tue, 26 February 2008 08:31
Daniel Gerlach is currently offline Daniel GerlachFriend
Member
i want to use two different mapping files. So i defined the
PersistenceOptions.MAPPING_FILE_PATH,
" C:/Users/gerlacdt/workspace/BpelFragmentMining/hibernate2.hb m.xml "). I
tried the absolute path and a relative one, but i always get this
exception:
org.eclipse.emf.teneo.hibernate.HbStoreException: Path to mapping file:
C:/Users/gerlacdt/workspace/BpelFragmentMining/hibernate2.hb m.xml does not
exist!
org.eclipse.emf.teneo.hibernate.HbSessionDataStore.mapModel( HbSessionDataStore.java:160)
org.eclipse.emf.teneo.hibernate.HbSessionDataStore.initializ e(HbSessionDataStore.java:74)
org.eclipse.emf.teneo.hibernate.HbBaseSessionDataStore.getSe ssionFactory(HbBaseSessionDataStore.java:55)
de.uni.stuttgart.gerlacdt.bpel.database.PostgresqlConfigurat ionFragments. <init>(PostgresqlConfigurationFragments.java:24)
at test.DatabaseTest1.createFragmentsTables(DatabaseTest1.java: 46)
Is there a special notation for defining the resource path? I saw that the
mapping file is loaded in HbSessionDataStore.class.mapmodel() method. But
my InputStream "is" is always null.
Code:
final InputStream is = this.getClass().getResourceAsStream(element);
Thanks in advance,
Daniel Gerlach
Previous Topic:[Teneo] newbie question: Using Teneo with Existing Database
Next Topic:Problem with Teneo Library Editor Tutorial
Current Time: Thu Jun 30 02:40:49 GMT 2022
Powered by FUDForum. Page generated in 0.01779 seconds
